Axle tool? - Speedzilla Motorcycle Message Forums
Old 09-03-2009, 11:35 PM
TrickLidz's Avatar
lidzduc.blogspot.com
Default Axle tool?
Anyone got the axle tool used to hold the axle from turning when installing? Aftermarket, or DOS, etc.
I'd like to see a picture of it so I know the right one to get.
999R with Ohlins forks.
TIA
http://lidzduc.blogspot.com/
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 09-03-2009, 11:43 PM
TrickLidz's Avatar
Is it this one?
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 09-03-2009, 11:46 PM
TrickLidz's Avatar
Or this one, that looks like the tool pictured in my repair manual, but I can't see how it would work with the extended pin as the Ohlins has no notch in the bottom???
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 09-04-2009, 03:17 AM
ohlins forks usually don't use the fork tool. That is a showa thing. I know the ohlins forks for my Sport are actually on the underside but not under the axle. What kinda (model) fork are you using. I think i might have a spare if you need one.
Old 09-04-2009, 03:38 AM
Can Afford To Be Critical
I got mine from Desmo Times. Great guy to deal with.
Ducati Parts by Desmo Times - The Home of DIY Ducati Maintenance.
Its in the "Tools" section.
Old 09-09-2009, 03:00 AM
I plan on making one myself. But as to your question,i think the second pic is it. The pins look to be spring loaded, so as you spin the axle and it lines up, the long pin pops into place to hold the axle in position. The short pin maintains pressure on the axle while tightening.
A piece of round stock with a dowel pin in it would work just fine.
Old 10-13-2009, 06:58 AM
Align the axle
-snug up the axle-nut to pull the components together
-set the pinch bolts on the far side
-torque the axle-nut to 25%
-set the pinch bolts on the nut side
-tighten the axle-nut to 100% torque.
Who needs the alignment tool?
