I'm trying to replace the rear brake caliper mounting bracket on my 916. The problem is I can not get the large retaining circlip back on - this holds the bracket in place and fits in a little groove when installed. It's under a lot of tension when installed, and I can not get it back into the groove. It has a hole at each end that I think are meant to take needle nose pliers or some such to spread apart, but I still can't get it to spread enough to re-install. Does anyone know a technique (or special tool?) will work? Tried heating the circlip in boiling water but no luck with that either.
Anyone?
Thanks.
