I'm looking to put a 998 engine into a 748 frame (not an R frame). I know there is a bit of work that will be needed, but if anyone can give me a quick little rundown of what is needed. I know new throttle bodies, but what else?
It should fit fine....you will need to relocate your coils, get a 998 ECU and you'll need to drill out the motor mounts on the frame as the 998 's are 12mm and the 748's are 10mm....I had to do it when I did the 996 conversion....otherwise theres a few smaller mods, but you should be fine!
