what Flywheel? - Speedzilla Motorcycle Message Forums
Old 07-31-2009, 04:36 AM
998Cruiser's Avatar
Default what Flywheel?
Hello!
I've decided to try a light weight flywheel on my 998 track bike.
I've looked at Motowheels' which is from Nichols and also Yoyodyne's version.
Which one should I choose? Does it matter? Is lighter better or is too light bad?
Any input appreciated.
cheers!
Old 08-07-2009, 01:25 AM
acruhl's Avatar
It's a personal preference thing.
I have a stock 998 and I woulnd't put a light flywheel in it for the track. My 996 has light everything and it's a little bit difficult to keep the engine spinning, although you can tell it's easier to pull side to side.
Nichols tends to make really good stuff.
'01 MV F4S
'02 998
www.asmaracing.com
www.desmosouthwest.com
Old 08-07-2009, 03:39 AM
998Cruiser's Avatar
That's interesting to hear!
I'll probably end up getting the lighter Nichols wheel just to try to see if I like it.
Since the stock 998 doesn't have the light crank, or anything light, it might work just fine.
I also have the surflex slipper and light weight basket which helps too.
I've also been looking at swapping the engine for a late 999 instead of upgrading the stock one with hot cams etc. But that will be a later mission.
Old 08-07-2009, 03:55 AM
acruhl's Avatar
I don't know about light baskets. They spin opposite the crank. I think it's not a bad idea in general to take weight off the engine, but as far as affecting the gyroscopic effect, I'm just not sure about that.
As for cams, I keep an eye out for S cams or just the later 999 ones. Apparently they are drop in replacements. You'd want to get a new map on it for them though. Seems like fun. Although the stock bike seems plenty fast enough to do squid sniping. If you get a half talented one on a 600 though it makes life difficult.
'01 MV F4S
'02 998
www.asmaracing.com
Old 08-09-2009, 05:20 PM
I've got Nichols flywheels on both my SPS and my wife's monster and really like them... One plus about their units is they will take them back if you are not satisfied. Get the flywheel nuts also if you end up pulling the trigger.
2000 996 SPS #1203
Old 08-10-2009, 04:13 PM
duc572's Avatar
Varmint-Kong
+1 on what Tornado said....I have the Nic flywheel and lock nuts and love what it did for the bike.
Check your MBP rockers......Check your MBP valves......
http://www.visi.com/~moperfserv/road_trip.htm
Old 08-11-2009, 06:53 AM
DucMarauder's Avatar
Stiffy Member
Something to remember is the crank in the 998 has a much shorter stroke than the 996. Accordingly the stock 998 flywheel is a tad heftier. If Nicholds uses the same flywheel, the 998 just might have a tad more stalling issues. Just bump the idle a bit. On the same note it should spin up quite nicely......
Old 10-09-2009, 06:19 AM
998Cruiser's Avatar
Just to follow up here... I ended up installing Nichols fly wheel on the 998 and like the new bike. I had to change the slipper clutch a bit to compensate for the changed engine breaking.
It's also a bit different doing race starts, but other than that, I won't go back.
cheers guys!
Old 10-09-2009, 05:54 PM
Thanks for the update...I was curious what you ended up with.
2000 996 SPS #1203
