Bearings in the freezer/cases in the oven - Page 3 - Speedzilla Motorcycle Message Forums
  #41 (permalink)
Old 07-19-2009, 06:46 AM
Photon's Avatar
996
I got lucky again, the original shims are small enough for me to measure actual end float with the new bearings (.1016mm), so I add .15 to this and get .2516, divide that by two and get .1258 that I need to add to the shim size.
Does anybody want to buy two SKF bearings, they have zero miles on them.
  #42 (permalink)
Old 07-19-2009, 10:54 PM
916duc's Avatar
Joshua,
You really don't need to split that figure and add it to each side. You can use two different shims to combine total measurement needed. Just put the thicker of the two on the ride side end of the crank.......
  #43 (permalink)
Old 07-20-2009, 03:10 AM
Photon's Avatar
996
Thanks man,
I'm just documenting the math for posterity, one of my original shims is a 2.1mm, I'll just use that and make up the difference on the other side.
Why can the clutch side take the fatter shim?
  #44 (permalink)
Old 07-20-2009, 05:26 AM
916duc's Avatar
Just going by the book..... they state: in the event of two different sized shims, put the thicker on the right end of the crank. Didn't state exactly why........
  #45 (permalink)
Old 07-22-2009, 12:15 AM
Photon's Avatar
996
916duc- I received those shims today, thank you sir. I just had to lap off .06mm from the smaller of the two and combine that with the 2.1mm that I had, not bad at all, I guess this is just more proof that the SKFs were wrong
I assume you got the dinero, let me know if not.
Nice packaging for the shims by the way...
Name:  shime package.jpg
I'm glad that the post office didn't sniff these out thinking that we were trying to smuggle tobacco across state lines
  #46 (permalink)
Old 07-22-2009, 01:17 AM
916duc's Avatar
L O L ......
  #47 (permalink)
Old 07-27-2009, 02:14 AM
DucMarauder's Avatar
Stiffy Member
I think it had to do with the older style engines with the helical cut timing gears creating thrust loads on the crank.
  #48 (permalink)
Old 07-27-2009, 02:33 AM
bruntr's Avatar
Funny thing is I found myself doing the same thing this weekend....I have been swaping over internals to a new motor after my cases cracked in half. Anyway good news for me is I did not need to re-shim anything during the swap, everthing was dead on!
Current rides
1993 966SS animal
1987 700 Suzuki Intruder
  #49 (permalink)
Old 08-07-2009, 01:40 AM
acruhl's Avatar
I'm way late to this party, and I didn't read every single word so I'm probably repeating something.
Seems like a bad idea to me to use aftermarket crank bearings. With those you really don't know what preload to use, and you might need wacky shims (I think you did?). Glad to see you got stock ones. You know they are going to work. The extra money is worth the peace of mind and not having to do it again later.
Then again, the Ducati spec for crank preload is stupidly high, in my opinion (if you do the math on metal expansion). Apparently others agree. I set my 996 around .008". Also, I saw you measuring case halves like the manual says, that's hooey. Just borrow skinny shims and measure end float (I think you did this), then do the math from there.
I had to change the steel case inserts for the main bearings on mine. Putting in the bearings was a total snap though. Set the oven for around 300, put the cases in there a half hour or so. Put the bearings in the freezer overnight. They literally drop right in, as everyone is saying.
Are copper base gaskets really a good idea? Seems like they could deform slowly over time? Head gaskets seem like a decent idea, although I still used stock ones.
'01 MV F4S
'02 998
www.asmaracing.com
www.desmosouthwest.com
  #50 (permalink)
Old 08-07-2009, 07:49 PM
Photon's Avatar
996
My factory manual says .15mm(.006") for pre-load
I had to change the steel case inserts for the main bearings on mine. Putting in the bearings was a total snap though. Set the oven for around 300.
The initial time I heated the cases up to 100C(212F) per the manual, no problems. When I pulled the SKF's out, I just used a heat gun and a non-contact thermometer, as I had all the other bearings in and didn't want any grease in the oven. This worked fine.
From what I understand, copper doesn't really have a problem with compressing too much, it will conform to the gasket surfaces, but it's thickness stays the same. I used copper for the base gaskets to get my squish where I wanted it, as I could get them in different thicknesses same as the head gaskets, plus they're reusable a couple of times at least. I plan on pulling the heads off this winter to check on things, and most likely have the cylinders re-plated. I'll measure the gaskets then and see if they have compressed.
  #51 (permalink)
Old 08-08-2009, 05:12 AM
acruhl's Avatar
I think there was a factory bulletin at some point that said to set it to .30mm. I'm not sure if they changed it back yet.
.30mm means that it's almost difficult to turn the crank by hand.
'01 MV F4S
'02 998
www.asmaracing.com
  #52 (permalink)
Old 08-09-2009, 05:19 AM
desmo11's Avatar
I've never had good luck with copper.
A copper gasket w/gasgacinch on the base gasket is a whole different deal than a head gasket though...
I'd suggest calling cometic for a custom thickness head gasket if you need one.
That's what I did....
  #53 (permalink)
Old 08-09-2009, 05:23 PM
chris steedman's Avatar
Changing the subject a bit. Those aftermarket crankshims ? What sizes do they come in ? Where can i buy some and do they have the chamfer in them like the OE ones ?
life is work
www.hypertrick.net
www.bikeboy.org
  #54 (permalink)
Old 08-09-2009, 09:39 PM
916duc's Avatar
Precision Brand | Products
Size assortment shown in the page link above
[United Kingdom] Linear Tools, Ltd
Isleworth Middlesex
United Kingdom P:020 8400 2020
F:020 8400 2021
email:
sales@lineartools.co.uk
web:
Linear Tools // Tooling For The Future
  #55 (permalink)
Old 08-10-2009, 02:38 AM
Stiffy Member
I'm not seeing anything on their site suggesting so. So if not aware it could bugger ones day while sitting on the crank journal radius.
  #56 (permalink)
Old 08-10-2009, 05:30 AM
Photon's Avatar
996
No chamfer on those shims, had to cut it in.
  #57 (permalink)
Old 08-11-2009, 06:55 AM
Stiffy Member
Perfect!
