Does anyone know where I can get instructions for removing my monoposto setup from my 749s and switching to the biposto setup? I have all the parts for the biposto, just wanted to know what to expect when I get into it. Any help from someone who has done it would be much appreciated.
Remove the two side black plastic pieces under the seat.
Lift the tank up at the rear and remove the big bolt holding the seat and tail assembly.
Remove the seat and tail cowl.
Undo the bolts holding the exhaust canister.
Remove the 4 bolts holding the subframe.
Pull the subframe.
Do the reverse for the biposto assembly.
Voila.
Thank-you. That is what I was looking for. I did not know how you removed the seat from the tank. I knew they were attached, but didn't know how difficult it was to separate them.
