Thanks for the new addy. I hope you get your stuff worked out with the old site.
So what eprom would you recommend? 1999 748/853, stock cams/heads, Gianelli silencers (slip ons), 996 50mm dual throttle body, lightened crank and a Power CommanderIII usb.
Do I need to disconnect one side of the injectors? if so which ones.
Or would I need a different eprom? Would one from a 996 work?
I have the stock 748 one and the eprom from Gianelli.
I would like to get and use VDSTS, but IIRC, you need the stock eprom for it to work. I could be wrong on that, I havent read about it since I had it for my GT1000 I used to have.
Doug
