Belly pan - Speedzilla Motorcycle Message Forums
Old 04-03-2009, 02:29 AM
Default Belly pan
I want to put a belly pan on the stock 996 bodywork....how much material needs to be cut off? I want to retain the kickstand as well. Looking at a bunch of pictures it looks like there are several versions but all need a good amount chopped off the OEM side panels?
Old 04-03-2009, 03:11 AM
brettmess24's Avatar
Actually not a whole lot gets cut off. Why not just buy some aftermarket sides from sharkskinz or catalyst and have them painted. They will match great with a DP carbon bellypan.
Black 1098S
06 Triumph 675
Old 04-03-2009, 12:32 PM
yeah I was thinking of doing that but didnt want to go through the hassle of painting etc....
Old 04-04-2009, 07:26 PM
I cut some carbon side panels to fit a belly pan, and have the remnant sitting around if you want a reference. You're basically cutting at the lowest portion where there is a crease or bend starting. The only thing that requires extra planning is to make the sidestand cutout match up. It's hard to line it up to make a trace for proper fitment, but it can be done.
sorry for the ginormous photos -----
Old 04-06-2009, 06:36 PM
Dan,
When you come by to measure the rear wheels over here, can you bring those two pieces so we can make a tracing of it?
I'd like to send it out to customers that need templates to cut out the original sides when they get a belly pan from us.
-M
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 04-07-2009, 06:59 AM
I can bring it on my next trip there, no problem.
