I got a 999 master cylinder w/ the built in resivor for my 916. Having clearence issues w/ the resivor on the clipon. Any one ever done this before?
What do I need to do?
Did a search and didn't find any thing.
Thanks,
just use the clipons from a 999/749. They aren't hinged, so you will have to remove your top triple, but they will fit right on and everything will go together nice and neat!
Thanks,
I have a set of woodcraft clip ons from my 749 but the 916 fork tubes are a bit bigger. I was going to try using the resivor off the 916 just find a place to mount it and get a longer hose. Gotta keep this cheep or I should've just got a Brembo GP master.
Fred at Yoyodyne has the little push in 90 degree fittings so you can use a 749/999 master with the 916/1098 reservoir. Or if you still have the stock master you could harvest it from there.
