989 TPS setting? - Speedzilla Motorcycle Message Forums
Old 03-23-2009, 04:16 AM
998Cruiser's Avatar
Default 989 TPS setting?
Hello,
Is the TPS on the 998 set/reset with the Mathesis/VDST or by reading the voltage of the sensor?
cheers
Old 03-23-2009, 11:01 AM
voltage at the sensor.
Brad The Bike Boy
www.bikeboy.org
Old 03-23-2009, 04:02 PM
You can check it with a digital volt meter. With the front throttle plate fully closed you want to rotate and adjust the TPS to 150 mV.
The home method:
Cut a slit in the sheath on the wires to the TPS. With small pins you can probe the purple/white and the red/white wires. These are where you read the milivolts for the setting. It'll take a few tries as when you secure the TPS the readings will change. I put a small length of wire on the red/white harness wire that exits the harness for future ease in measurement. ** Be sure to seal it all up with rtv and tape to keep water out.
I checked the reading several years later and it only drifted a couple mV from my 150 setting.
02 998 La Strega Bella
Old 03-24-2009, 03:02 AM
998Cruiser's Avatar
Thanks guys!
I was confused because the 998 has the new computer but still is using what looks like the old non linear sensor.
cheers
Old 03-26-2009, 10:03 AM
998Cruiser's Avatar
I just measured the TPS, it read 75 mV. I tweaked it to read 150 mV as suggested and secured it.
The bike started just fine. I can't take it for a spin as it's my track bike and it's dark here at the moment. It's been hard to cold start, now it started right away. I'll see how it works over the next couple of weeks.
Was the 75 mV way off or within acceptable tolerance?
So yea, pretty straight forward, I'll get to try the bike on the track next weekend.
Thanks for the help!
Old 03-26-2009, 10:06 AM
998Cruiser's Avatar
Here we are at the Cemetery Street race, NZ!
Old 03-26-2009, 11:03 PM
75 is waaay lean. It should run much better now and you'll notice it is generally smoother through the range.
Old 03-26-2009, 11:10 PM
998Cruiser's Avatar
Ok, I'll be interesting to see how it runs now. It wasn't bad before, but things can always improve.
I guess the PowerCommander richened it up a bit, now I'm curious, is it too rich now or just perfect.
Obviously, I should have done the TPS before the PC dyno tweaks, but I didn't know better back then. Although, the dealer should have sugested to sort out the TPS and throttle bodies first, one would think.
I've also balanced the throttle bodies, they were also way off.
Old 03-26-2009, 11:40 PM
vij vij is offline
www.virdung.net
A lot of dealers have no idea what they are doing. Some should not be allowed to touch bikes at all.
Where are you based?
AB:s in Nelson knows there stuff as far as I know. Are you in the south or north?
Jocke.......
MHR 900 1984
S4 984 2002
www.virdung.net
Old 03-27-2009, 03:43 PM
redtop's Avatar
Hmmm...
If you do a custom mapping with the TPS at something-else-than-150mV then you should be fine since you have a map that is optimized for something-else-than-150mV.
But if you change your TPS setting to 150mV, then your optimized custom mapping would not be optimized anymore, since the ECU will be looking in the wrong place of the map for a certain throttle opening angle.
Or in another way: changing the TPS setting is equal to changing the throttle breakpoints in the map.
Setting the TPS to a certain voltage (Ducati has choosen 150mV) is just a way to get different bikes less different to be able to use standard maps for all bikes.
Just my 5c...
Forget the abow, I completely forgot the ignition map, that hasn't been changed and of course would be most happy with the 150mV setting.
/RedTop
http://bimota-db2.blogspot.com/
Old 03-27-2009, 09:21 PM
Superlight's Avatar
Totally OT, but do you have a swedish flag on yer bike? If so, why?
Rgds Markus
Old 03-27-2009, 11:44 PM
998Cruiser's Avatar
redtop, I agree with what you said, messing with the TPS after a custom map been made would probably mess up things.
That said, I haven't done a custom map yet, I was going to wait till I install 999r cams. I'm not sure what that is going to happen though... I sorta promised myself not to do any engine mods the first year, just learn to ride the thing first.
Old 03-27-2009, 11:47 PM
998Cruiser's Avatar
Rgds Markus
Because I'm a Swedish living in NZ!
Jag kommer från Kalmar.
Tjena!
Old 03-28-2009, 07:45 AM
TomTom's Avatar
Also you may want to check that the throttle bodies open fully, on one 998 i mapped I had to grind the stop quite a bit to make it open fully.
Hej på er!
Old 03-28-2009, 09:12 AM
vij vij is offline
www.virdung.net
Tjena!
Oh noo. Another one. Swedes everywere
Jag kommer från Linköping.
I am Swedish living in France. Married to a girl from Nelson NZ.
Were are you in NZ?
Jocke.....
MHR 900 1984
S4 984 2002
www.virdung.net
Old 03-28-2009, 10:23 AM
Superlight's Avatar
Tjena!
I was just wondering because my wife lived in Nelson for a year and one of her best friend's dad is living in Nelson.
Ajöken!
Old 03-28-2009, 11:18 AM
Super Moderator
So in the end you´re all relatives?
Old 03-28-2009, 11:55 AM
998Cruiser's Avatar
Hej på er!
Tjena!
I just got back from the pub and saw your post. I went down to the garage and had a look. I'd say the throttle bodies opens up about 85 degrees at full throttle twist. I have to connect the VDST to get the actual reading.
I can see the opening is stopped by the arm holding the idle screw. Is this the one you grinded off? Are the throttle bodies supposed to open fully 90 degrees?
cheers
johan
Old 03-28-2009, 01:14 PM
vij vij is offline
www.virdung.net
Yes we are. We are also going to rename this place to swedezilla.com
Jocke............
MHR 900 1984
S4 984 2002
www.virdung.net
Old 03-30-2009, 11:35 AM
TomTom's Avatar
Tjena!
cheers
johan
Grinded the arm yes. The bike I referred to was more like 70, 85 is ok.
