Old 02-27-2009, 10:00 PM
Ben710's Avatar
Ben710 Ben710 is online now
Default Showa shock rebuild info
Does anyone have detailed information on a Ducati 916 Showa shock rebuild?
I want to do it with my shock, but I donīt know how much fluid, what type of fluid and how much gas pressure I need.
Also, does anyone know the spring rate of a stock biposto rear shock spring?
powerwheelie racing weblog
Old 02-27-2009, 10:03 PM
duckracer duckracer is offline
Call Jason at Department of suspension. He will rebuild it for a good price. But if you still wan to do it yourself he may be able to answer your questions.
Old 02-27-2009, 10:11 PM
Ben710's Avatar
Thanks for your reply though!
Old 02-27-2009, 11:22 PM
BC999S BC999S is offline
Can Afford To Be Critical
Not a direct answer to your questin but Racetech Suspension sells high quality re-valve kits which come with comprehensive instructions.
I've done two Showa shocks for the street and they're excellent. $170USD
For what its worth, I'm running 200 psi in these shocks.
Race Tech Inc.
Click on "sportbikes" then search under "street product search".
Hope this helps.
Old 03-01-2009, 12:42 AM
sideways sideways is offline
Dis Member
The Honda shop should have some good showa shock oil. I think two little bottles will do, depends on how much of a mess you make. I think it is 2.5W?? SS25?? I use anywhere from 150 to 200psi or whatever the the nut on the bike says feels good.
just my
I saw a 1999 ST4 come in this winter with 50psi.
Carrmoto
Ducati Indianapolis
IndyDucati
Đ 2007, Speedzilla.com, Inc
