748
thanks for the info: took this from the sigma site ..still leaves a few questions ,like the last line. the chart did not copy well so I left it out .
There is one manual adjustment, the trimmer. This is intended to allow small adjustments in mixture at low revs. The chart below shows the effect the trimmer (either a small grub screw in the computer or a Program on a PC; depends on the computer type).
Note that a mixture change of 1.5% is required to move the exhaust Lambda by one point (i.e. from 0.90 to 0.91) so the available range is pretty large. While the trimmer will have some effect at high rpm it provides the inverse of what is needed to accommodate an open pipe or a freer breathing engine.
