oil filter leaking - Speedzilla Motorcycle Message Forums
Old 02-13-2009, 05:46 AM
ducduc's Avatar
Default oil filter leaking
Hey,
My effing oil filter started leaking and I tried tightening it to no effect. Can I remove the filter without the oil all draining out? I just changed my oil and I really dont want to drain it twice. Any help would be nice.
THanks
Blake
01 748s
00 996 SPS (sold)
01 RSVR (sold)
98 Monster (sold)
98 900ss (sold)
02 998 (sold)
06 R6 (sold)
06 GSXR (sold)
99 tl1000s (sold)
69 cb350 cafe (sold)
Old 02-13-2009, 07:52 AM
Super Moderator
No you canŽt.
If you could, IŽd be worried
If the oil is new, drain it into a clean pan and reuse it.
Old 02-13-2009, 08:03 AM
Absolutely!!! Turn the bike upside down! There is always a solution to the problem. Let me know how that goes.
PS. For a better approach try to loosen up the filter, sometimes they get a "wrinkle" in the seal, you can then either retighten or leave it if its tight still.
Old 02-13-2009, 11:04 PM
You won't loose all the oil just about 1qt maybe a bit more. Did you check the old filter to make sure the seal did not stick to the engine? Just change the filter and replace the lost amount of oil.
Old 03-29-2009, 05:07 AM
Originally Posted by ducduc View Post
Hey,
THanks
Blake
You've probably solved this problem by now, so was it actually the oil filter or was it leaking from the steel braided oil cooler lines right where they connect to the engine block, and then running down and falling off of the oil filter?
_________________________________________________
