998 <-> 999s cams? - Speedzilla Motorcycle Message Forums
Old 02-12-2009, 11:48 PM
998Cruiser's Avatar
Question 998 <-> 999s cams?
Hello!
I have a '02 998 US that I'm riding on the track only. The engine is more or less stock except for a full 50mm exhaust and a power commander.
I've done suspension and wheel upgrades already, a slipper too.
It has the 'lazy' cams and the non deep sump engine.
Is it possible to install the 'hot' cams from a 999s into this engine?
The part numbers of the cams I'm looking at are:
14820792B / 14820801B / 14820782B / 14820811B
Is it plug and play or does it require any other parts?
cheers!!
Old 02-13-2009, 12:39 AM
TomTom's Avatar
It sure is plug and play, need to check the valve clearances, but to me swapping cams in ducatis, it wont need much, they are consistent as far as I know. I have two swaps from 999 to 999s cams, no probs. 998 and 999 is the exact same engine so they will interact.
Old 02-13-2009, 02:29 AM
demontech's Avatar
livin the high life
need a set?
Old 02-14-2009, 07:09 PM
Default cam switch
What kind of gains can one expect from swapping the cams?
Old 02-14-2009, 07:52 PM
Super Moderator
Should be roughly 10-15 HP. The base engines in the 998 and 999 will make roughly 128-130 HP (engine) and the 998S/999S will make roughly 145.
Old 02-14-2009, 08:56 PM
+1 especially if you have a larger header pipe, the cams dont gain you much without a pipe and visa versa.
Making Ducs fly since 1991
Old 02-15-2009, 06:10 AM
Old Baldy's Avatar
I've a senior member
How much are used 998R EU/999S cams going for, these days?
Old Baldy / WWBO #451
Ducati 996
Kawasaki KLR 650 '02
Kawasaki KLR650 '06
OB's Blog
Old 02-15-2009, 08:03 AM
Super Moderator
Look at ebay Baldy, there is a set or two right now.
I think 400 for a complete set intake and exhaust is what I saw yesterday. Maybe a bit more.
Old 02-15-2009, 03:45 PM
$400 is what I paid for a set of s heads ,which in the 749 had bigger valves as well . I'm now thinking I should have gone for 999 heads which would have had even larger valves .
Old 02-15-2009, 05:11 PM
Dis Member
Have you tried the 749s heads on a stock 999 bottom end? I have one put together but have not run it yet. I am thinking it will be about mid 130's with a nice pipe and tune and stock pistons. No porting or anything, just stock 749s heads at 1mm squish above a stock 999 piston and bottom end.
IMHO no matter what the HP, the ti keepers give me comfort.
IndyDucati
Old 02-15-2009, 05:13 PM
Dis Member
Make sure you have part number confirmation, I see those get mixed up alot.
IndyDucati
Old 02-16-2009, 12:34 AM
chris steedman's Avatar
That should have some good compression with its tiny combustion chamber Will be interesting
life is work
www.hypertrick.net
www.bikeboy.org
Old 02-16-2009, 01:37 AM
998Cruiser's Avatar
Thanks for all the replies.
It sound like you gain a lot of power with this simple mod, so I think it's worth doing.
Would the maintenance schedule of the 999s cams be a lot different from the std cams?
cheers
Old 02-16-2009, 01:54 PM
amullo's Avatar
916SPS user
Send a message via MSN to amullo
Should not be.. They share the same service intervall..
//amullo
Old 02-16-2009, 09:43 PM
Old Baldy's Avatar
Thanks Ben. I think I was too late to see it, although I saw some 998S cams which are probably US spec. Haven;t cross-referenced the part numbers , so if they are the UK spec, then they'd be a steal.
Ducati 996
Kawasaki KLR650 '06
OB's Blog
Old 02-16-2009, 09:57 PM
Super Moderator
Anytime dude.
Drop chris steedman a PM. Last time I asked, he could get them for a reasonable price.
Old 02-17-2009, 12:15 AM
There were no true S camed 998's in the U.S. but we did get them in the 999S and later standard 999's. We have a used set of the 999S cams which are a drop in for any 998/999.
Old 02-18-2009, 12:24 AM
Old Baldy's Avatar
Anytime dude.
Chris has sorted me out with a set of EU 998S pattern cams.
thx
Ducati 996
Kawasaki KLR650 '06
OB's Blog
