748R clutch basket exchange - Speedzilla Motorcycle Message Forums
Old 10-01-2008, 12:34 PM
Default 748R clutch basket exchange
I’m planning for the winter the exchange of the original 748R basket for one in alloy.
This will be a little long and the English might not be the best so be gentle with me J
I ask for help on if is needed any special tools, parts or tricks that should know.
I have:
- New alloy basket
- New alloy pressure plate
- A new spider spring
- New alloy clutch disks
I’m going to buy:
- New stainless springs
- New stainless bolts for the posts. What is the size of the bolt? I want to buy a bolt with torx head! I think they are better than the allen. Anyone saw them in the BMW bikes!
- New alloy caps for the springs
This procedure I think will be this:
- Take the cover off
- Take the bolts out
- Take springs off
- Get the pressure plate with the rod
First question – How do I get out the rod from the pressure plate? Do I need a special tool?
- Put the rod in the new pressure plate
- Take out the clutch disks – See the order of the disks, put a strap around the disks
- Put the bike in first gear, and ask for someone to hold the brake. (I will do a tool with the old disks)
- Take the big nut that holds the hub.
Second question – What is the size of this nut? I will use electric impact driver I need to see if I have the socket for it.
- Take the hub out.
- Take the flange out
- Get out the 8 screws that hold the basket in place.
Third question – What is the size of these bolts? I want replace this for the same bolt in AISI 316.
I think that is all in the disassembly.
The assembly will be the opposite.
Some thoughts:
- In which bolts should I use threadlocker and what strength to use?
- Will I have problems with the alloy/stainless steel interaction.
- Can I use copper paste to lubricate the ramps or the moly paste is best?
- What torques should I know?
- On the exploded view of the manual on the assembly of the clutch disks shows first two plain disks is this the right way?
These are the questions that I have for now.
I will take some pictures of the procedure.
Thank you for your time
Pedro
748R '02 - Fantastic Bike
748SP '97(sold)
900SS '94(sold)
Cagiva Prima R '95 (sold)
Old 10-01-2008, 09:15 PM
Super Moderator
Good post man! I wish all of us here would do it this way.
***just tap it with a hammer and some flat surfaced bolt.
***I think it is a 32mm one. Or was it a 28? Something that I have in my toolbox.
*** I used red loctite (bottle is red, fluid is green I think). I use it on the ones that hold the basket. That´s it.
*** Well steel is harder than aluminum. Alu plates with alu discs would be better.
*** copper paste is good, but I don´t think you need a lot of that. If any. You can run it dry as well.
* The big nut that´s on the crankshaft is 180nm. The inner bolts... hmmm cant remember. Something around 60? Don´t have my workshop manual here now. Sorry.
***No, the stack for the slippers are different. First driving plate because it´s thicker. Then driven plate, driving plate, spring plate, mix mix mix, spring plate, mix mix and end with driven plates.
Old 11-20-2008, 10:26 AM
Finally i have the 748R manual.
Ducati recommends Loctite 510 for the bolts holding the basket and Loctite 128455 for the hub nut.
http://tds.loctite.com/tds5/docs/510-EN.PDF
http://www.loctite.tv/template/ying/.../128455-EN.PDF
What type is normally used?
Thank you
Pedro
748SP '97(sold)
900SS '94(sold)
Old 11-21-2008, 05:30 PM
Super Moderator
The one in the red tube I have in my basement...
I always use the green (middle) stuff.
Don´t worry too much about it Pedro. Put a dot of Loctite onto the basket bolts. I never glued in the big center nut. And it never fell apart.
Old 11-23-2008, 11:46 PM
I think the nut is a 32mm and the torque value is 132ft.lbs
The baskets bolt torque values are 28ft.lb.
You seem to have it all laid out here, so I foresee you having no problems at all. I used a little black silicone adhesive to secure my basket bolts. The stuff that ducati uses is kind of the same but gray in color. I've done two clutch overhauls and have used this permatex stuff w/o issue! Be sure to grease the inside of the rod cap and tip of the push rod itself before reinstalling and put a little oil on the spring hold down screws too and your good to go!
