Featured Photos
by 300zx
Member Galleries
2078 photos
644 comments
by C. Dolan
Bike Pics
83 photos
44 comments
by jwm2k3
MV Agusta F4 1000S
20 photos
6 comments
by Mr.Stealth
Member Galleries
2078 photos
644 comments
Old 08-28-2008, 05:28 AM
lushbaugh-00'748 lushbaugh-00'748 is offline
senior member,not citizen
Default a few questions........
for those of you who have done the testastretta swap into a 748,916,996.
first i know you have to make spacers for between the motor and frame but is all the spacing to one side or split evenly to get the chain to line up?
next is what throttle bodies are you using? stock shower type or 996 dual injectors.
and last what harness and ecu? i was going to use a 998 harness but if i could use the stock one and get an eprom made for my ecu that would be great. thanks for all help in advance,
chris
2000 748 biposto
awaiting heart transplant....
Old 08-28-2008, 03:40 PM
TomTom's Avatar
TomTom TomTom is online now
You can check with Connander or ActionJacksen here on the board about fitting the engine, I beleive they fit straigh in without any spacers.
If you use the 1.6 computer and 998 or 999 throttlebodies I have eprom for that combo.
Stock 5.9 ecu reprogramming, mapping www.HyperTrick.net
Engine porting, balancing etc www.cjsracing.co.uk
Old 08-28-2008, 04:22 PM
i can burn eproms...well i have all the epuipment but i cant figure out how to drag the maps onto the burner program and write it.....would you be willing to sell an eprom?....im determined to do this. i was hoping you would chime in.
2000 748 biposto
Old 08-28-2008, 05:20 PM
TomTom's Avatar
You just need to spend an unhealthy amount of time digging the files
Seriously, of course I have one for you. You got pm.
Old 08-28-2008, 05:37 PM
pm replied tomtom
2000 748 biposto
Old 08-28-2008, 06:23 PM
hubert's Avatar
hubert hubert is offline
You're also going to need to get a 998 exhaust or have your current setup modified. And a 998 or 748R airbox.
Good luck with your swap, I've thought about doing this with my 996 sometime ( a long time) in the future.
Turn down the suck knob.
Old 08-28-2008, 06:30 PM
yea i know but i only had a 45mm half termi system and ill sell it to recoup some cash.....i think you need a 996r,996rs or 998s exhaust because the 999 motor is deep sump...i think
thanks for the heads up tho
2000 748 biposto
Old 08-28-2008, 07:53 PM
chris steedman's Avatar
chris steedman chris steedman is offline
If you are using a non R or sps type 916/748 frame you can still fit 998 throttle bodies with a small amount of trimming. The 999 throttle bodies wont fit unless you cut the frame.
life is work
For Ducati engine blueprinting/crank balancing/performance cylinderhead worx-www.cjsracing.co.uk
For spot on dyno-tuning ,mapping, custom eproms-
www.hypertrick.net coming soon..
Old 08-28-2008, 08:11 PM
yea its a base model....im taking my frame to a local shop and using one of there motors to mock up and trim the cross bar...then the frame is off to the powder coaters
2000 748 biposto
