999R 04 models - power and heat? - Speedzilla Motorcycle Message Forums
Old 06-12-2008, 12:20 AM
Super Moderator
Default 999R 04 models - power and heat?
Hey everyone,
I dyno´ed my 999R today. 153,5 HP at the crankshaft.
It has a 57mm Termi system, a reflashed DP ECU and big valves with done ports.
My buddies 999S 06 made 152 HP bone stock... did all 04 999R have some kind of low power? I was a little surprised to be honest. I expected something like 158-160 with big valves and 152-155 stock.
Also - my machine is running quite hot. On the dyno we could make one run at 80°C. Then the temp went up to above 100 when the fans kicked in. The dyno guy let it run in neutral for a while with the dyno fans running, but it didn´t cool down very fast. After two minutes it cooled down to like 98°C.
After that I test rode it on the street in 1st and 2nd gear a few hundred meters. It never got below 100°C. Sure, I don´t have the full cooling wind that I would have on the track. But still, isn´t that a bit odd/hot? I lost 5 HP from the first 80° dyo run to the 2nd 100° run. I hate losing power...
Any ideas?
Old 06-12-2008, 01:49 AM
trussdude's Avatar
I have never seen a stock 999s that high. A stock 999r is good for about 142 rwhp.
www.ballsacracing.com
Old 06-12-2008, 02:54 AM
Default ben710
you quoted crank horse power ....is this an error or a calculation ?
Old 06-12-2008, 10:20 AM
Super Moderator
The P4 Ammerschläger dyno measures at the engine, not at the rear wheel.
Old 06-12-2008, 10:57 AM
MV-999R's Avatar
Ben check out the cooling system on that bike.
Never getting below 100º C on the street is not usual
Old 06-12-2008, 02:47 PM
chris steedman's Avatar
Originally Posted by Ben710 View Post
Hey everyone,
Any ideas?
The older 999r did not make much more power than a 998s. The new 999r has bigger valves/more compression and higher lifting cams as standard.
It is possible to get the older bike to make good power but the heads need to be done right so does the camtiming.
On our dyno 998s 100mm bore makes 133
999r makes 136
new 999r makes 142
With your 104mm bore and heads i would have liked to have seen 145-148 without pistons. The new 999r can pull 160 or more fully built on race gas (i know marc from ducshop did one here think it belongs to trussdude)
life is work
www.hypertrick.net
www.bikeboy.org
Old 06-12-2008, 03:35 PM
Default 710
not to pick nits but the dyno must calculate crank horse power unless the engine is in fact out of the motorcycle . Losses in the final drive and transmission and tire to road must be calculated out in order to get crank horse/power. True crank horse power is measured in a test cell where power is measured from the crank.
My real reason for asking was to find out what the calculation was for friction loss. MY Guess ....In your case they would be adding something around 15% to whatever was measured at the rear wheel.
Old 06-12-2008, 04:03 PM
Default 710
it is normal for Ducati to give crank horse/power for their engines ,these numbers are always larger than what can be observed in real world testing where friction losses are part of the picture. Crank horse/power in your case only has meaning if you know what amount was added to the measured horse/power.
Old 06-12-2008, 07:26 PM
reca999r's Avatar
I have on mi 999r from 2004 148.5 Hp. I have the original motor. Termignoni 63 mm, nemesis ECU.
Old 06-12-2008, 07:40 PM
MV-999R's Avatar
Hola Reca,
Are you going to Cartagena for the Desafio Twin?
Old 06-12-2008, 08:13 PM
TomTom's Avatar
Dynoes will differ a lot, at best the same dyno with the same oprator will give a consequent result.
Either you compare before after or you toss in at least 5 other bikes for reference. Other than that can be anything.
Old 06-12-2008, 09:35 PM
Default Tt
point taken Tom ...I was trying to point out that it's ridiculous to quote crank horse/power when the readings are taken off the rear wheel .That is unless the dyno guy is trying to give the impression that the bike makes more power than it does.
Old 06-13-2008, 01:33 PM
Default tt
True Rear Wheel Horsepower
interesting reading .....
Old 06-16-2008, 11:53 AM
Super Moderator
I checked it out this weekend at the Lausitzring.
During the warm ups and the races I had roughly 90°C, maybe a bit more sometimes. Not perfect, but ok so far I think.
The engine feels great, has a lot of midrange power. Here´s the dyno graph by the way, just for you guys who are interested.
I ran against some guys from Denmark, who had Jason(?) Hackett from JHP build their 999R with 1098 crank and pistons. Unbelievable, how much power they got out of that engine. We have 2 guys in the series running that setup and both have around 180-186 HP at the engine. Nice, but they were a slight bit slower during the race. Seems like they couldn´t handle the power all too well. Anyway, I´m getting carried away...
Here´s the dyno graph.
Old 06-16-2008, 03:59 PM
drthompson65's Avatar
Interesting read! I'm happy with the ballpark HP that my 999S makes. Enough to scare the piss out of me.
Current Ride:
Old 06-16-2008, 11:18 PM
Default Crank HP figures from Ducati
FYI from Ducati.com website:
999S 999R 999
2003 136HP 139HP 124HP
2004 999S 999R "
136HP 139HP
2005 999S 999R 999
143HP 150HP 140HP
2006 999S 999R "
143HP 150HP
2007 1098 1098S
160HP 160HP
Numbers wouldn't line up, you get the picture.
2003 HD FLHRI
2003 Ducati 999R #189
2009 Buell 1125CR (sold)
2007 Ducati 1100S MTS (sold)
2005 Honda 600RR (totalled)
2001 Ducati 900SS (sold)
1995 Ducati 916 (sold)
2004 Ducati 999S (sold)
www.ducati-owners-group.com
Old 06-16-2008, 11:23 PM
My 04 999S makes around 145+ crank HP with a few mods and it does the same to me. The machine is plenty fast enough for what I do. I just started riding the bike after a long lay off, impressive power.
2003 HD FLHRI
Old 06-17-2008, 12:07 AM
mrgrn's Avatar
BEN, how often is the 180 hp bikes motors need opening?
nice graph though
www.carbonpartz.net
www.blackdragonexhaust.net
Old 06-17-2008, 06:24 AM
TomTom's Avatar
Ben, can you but a few stock bikes on top so we get the idea of what a stock bike makes in the p4?
Old 06-17-2008, 08:53 AM
Super Moderator
I can ask if he may give me the dyno results, won´t promise you anything though. Don´t know how busy or anal he is about his tuner porn
