EF 1 error on dash - Speedzilla Motorcycle Message Forums
Old 01-09-2008, 03:15 AM
Default EF 1 error on dash
My 999 just sent me this message.
anyone know what it means?
Old 01-10-2008, 04:02 PM
Default lost
I was looking in LT Snyder's book last night ,he lists the error codes and their meaning ....they are all numaric ...no sign of "EF"
good luck
Old 01-10-2008, 09:01 PM
I am really stuck on this one too. I don`t even know where to begin.
Old 01-11-2008, 12:23 AM
The instrument panel displays a series of error codes regarding the injection system and immobilizer. The EF 1 error symbol appears, and in the bottom RH cornor, the error code itself. If more than one error is present, the display will alternate between them every 3 seconds. What is the error code displayed? I'll look it up for you.
Source: 2005 999r factory shop manual, sect. M4 pg. 34
Old 01-11-2008, 11:49 AM
MV-999R's Avatar
Like Niel said you have to check the code that's displayed.
Here's the list of the error codes
Old 01-11-2008, 05:28 PM
I would love to give you the code, but when I turn the ignition on, this is the only message that I get. THe screen on the right hand side is completely blank.
The only two factors that I can think of are:
1) I have a new dash set (black key only) with the original ecu
2) I am missing the air temperature sensor (in the headlight pod)
In the meantime I have ordered a new ECU and temp sensor. I hope this works...
Old 01-26-2008, 02:35 AM
update:
In the end I didn`t get the new ECU because the ebay seller had 'issues'.
The Air temperature sensor has been installed, everything is in place and connected, but all I get when I check the error codes is EF1 and nothing.
I tried unplugging a few other wires just to see what would happen and I received errors such as EF1 19.2, 3.1, 34.0, 18.2, but when they were all reconnected it was back to the EF1 nothing.
As it stands the bike doesn`t start or turn over. It doesnt help that the temperature is well below freezing.
I was wondering if it is worth digging around deeper into the wiring ie around the injectors etc, should I replace the ECU?
Any advice will be appreciated, since I am going crazy here.
thanks
Old 01-29-2008, 04:19 PM
mailerdaemon's Avatar
I assume that you've tried disconnecting then reconnecting the dash?
I also assume that you've also tried disconnecting then reconnecting the battery?
Sorry I can't be of more help, but tell me...when you got the 34.0 error code, do you remember what you had disconnected?...as I have had this code in the past and never worked out why. I sort of came to the conclusion that the air pressure sensor (built into the circuit board in the dash) was the cause and a new dash was fitted. The 34.0 error has appeared again once though with the new dash.
'05 999s
Old 01-30-2008, 09:20 PM
I have tried disconnecting everything from the battery to the dash, sorry I don`t remember what I did to get the error 34.0, possible it was when I disconnected the ECU....
Old 09-07-2009, 07:50 AM
Superlight's Avatar
Maybe a stupid question with an obvious answer, but do the error codes disappear when the error is fixed?
Rgds Markus
Old 09-11-2009, 09:40 AM
Superlight's Avatar
Yes they do
