Departmentofsuspension - Long Swing-Arm Q. - Speedzilla Motorcycle Message Forums
Old 12-01-2006, 02:16 PM
Default Departmentofsuspension - Long Swing-Arm Q.
Supposing – just supposing that someone wanted to install your extended single-sided swing arm into an otherwise stock 999, would this work and would you just need the ride height adjuster bar from a 748 – 998?
(Obvoiusly wheel/hub/brake etc - I'm not that stoooopid)
Just day-dreaming here, you understand.
Spin
It's called the red-shift, and it's a result of the doppler effect. Basically, the faster something moves away from you, the redder it appears.
Old 12-01-2006, 02:46 PM
I actually have a short swing-arm. I have a 998.
Just interested to see if the long-jobby will drop into a 999 and how much jiggery-pokery would be required.
Spin
Old 12-05-2006, 08:43 AM
Many thanks for clearing that up for me.
He's just going to have to by a 1098.
Spin
Old 12-05-2006, 02:02 PM
Sorry you don't like them. I'll have yours. Spin
Old 12-06-2006, 12:17 PM
another possibility might be a different shock. They can be made in any length or configuration.
Old 12-07-2006, 01:45 AM
CuStOm's Avatar
Originally Posted by departmentofsuspension
Um, for what? To make the swingarm longer?
No silly, pay attention Its for what you said earlier in the post
You would need to raise the upper shock mount in the 999 frame so the shock would fit. Not a simple task.
Someone just forgot about travel
2003 ST4S-ABS / 2006 S2R1k / 853 Track Junkie Toy - Limited S8SBK Self-Implosion Edition (Now uber better 998)
