Looks like my 2001 996 has a problem
yesterday while riding, I noticed the clutch seemed to slip while in 3rd gear and really getting on the throttle. I continued to ride it home(about 4 miles) and it was definately slipping in 3rd when I hammered the throttle. Then, it appeared that I got the bike stuck in a high gear and when I went to downshift, I got to neutral but not any lower. I was finally able to kick back into what I assume was 2nd or possibly 3rd. When I got to my garage, I kicked the shifter around a few and was finally able to get 1st and then neutral. I bled the clutch slave, thinking it was not properly disengaging the clutch, but that did no change a thing. When the bike is sitting there, off; it is near impossible to shirt it. When running, you literally have to stop the lever to shift to first gear, second is just as bad. I did not go above second cause I only went down the driveway and turned around. When I went to shift to neutral, it was extremely stiff and I was kepy going to first or second cause i had to push pull on the lever so much. Afterwards, I removed the clutch cover and pulled all the plates, which still look new (clutch only has a few hundred miles on it) but the hub appears to wobble slightly when i rotate it by hand. Tonight I'm going to break loose the large nut in the center and remove the hub and then basket and inspect them.
Any ideas from you guys ? Think I have a shift fork issue ? If I were to pull the stator side case cover, is there anything specific to look at, regarding the shift linkage ?
Thanks,
Tom
