Big Hub Magnesium Swingarm - Speedzilla Motorcycle Message Forums
Old 11-26-2006, 01:57 PM
rjjablo's Avatar
Question Big Hub Magnesium Swingarm
A Big Axle/Hub Magnesium swingarms came up for sale on E-Bay. Item #330054301077
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=014
Question is, What other items would I need other than the Big Axle and the Big Axle Bearing to put this swingarm on the standard 748/916/996.
Do I need a new rear rim? Does they come in a 17 inch diameter.
Old 11-26-2006, 02:16 PM
rainman916's Avatar
hi you need the rear hub,axle, and rim.and shock linkage and i think the shock ,and the rear brake carrier is different also i think?the same person has the other items listed also,
(IN THE GARAGE)
1975 z1 900
1976kz900 ltd
1977kz1000
1981 gs1100
1984 gs1150
1984 fj1100 (1380 with progressive nos)
1986 fj1200
2000 turbo hayabusa( 400 hp)
95 ducati 916 (955)
f4 1000 mv
Old 11-26-2006, 04:24 PM
998R's Avatar
There are all kinds of bits you would need to make this "complete". I have the same swingarm complete (small axle) and it was a bit&* to get all the parts even though it was listed in the Ducati Superbike catalog. Tooks 2.5 months of the dealer yelling at DNA and Ducati Italy before everything was obtained. Upper shock rocker, rear brake and carrier, ride height adjuster, CF protection bits, upper and lower chain rubs, etc.
Plus...it doesn't appear like the swingarm has been coated like the factory swingarms are...this one looks like it has been polished.
I am not sure, but I also think you would need a special wheel to accomodate the large axle...which might be difficult to find.
Old 11-26-2006, 10:20 PM
Looks to me, and I am talking out of my A$$ here, but that swingarm in the picture could be either a OEM sized axel/hub/eccentric or the Corse one depending on what you put in the swingarm. The diameter of the axel/hub is basaed on the ID of the eccentric, not the swingarm.
But maybe the Corse swingarm has a bigger hole for the eccentric.
Old 11-26-2006, 10:48 PM
[QUOTE=
Do I need a new rear rim? Does they come in a 17 inch diameter.[/QUOTE]
You will need a wheel to fit the larger axle.
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 11-27-2006, 01:33 AM
JeffKoch's Avatar
Hmm, can't you simply use the stock eccentric hub and axle in the swingarm? If so, you could probably get by with just the swingarm, maybe with some modifications to the brake hanger as is necessary with the Marchesini swingarm - Nichols or probably Motowheels could explain. For my swingarm, I could have just swapped the swingarms, modified the brake caliper hanger, and stiffened the shock spring and compression damping. This is basically all you need for street applications, where you aren't going to a straight-rate shock linkage geometry.
I don't know any local Ducati racers who used the large axle, but parts must be very hard to find nowadays. I had a large-axle 16.5" rear wheel for a little while by mistake, and I think that's pretty much the only size you're likely to find (slicks only) - and good luck finding one of those.
08 Red Ducati 1098S
99 Black Ducati 996 (race)
Old 11-27-2006, 02:29 AM
mrgrn's Avatar
WOT
www.carbonpartz.net
www.blackdragonexhaust.net
Old 11-27-2006, 03:18 AM
rjjablo's Avatar
Default Big Hub Magnesium Swingarm
I was afraid the big hub/axle would be a 16.5 inch application only.
I am still working on getting the longer swingarm and am wondering if piecing together parts off E-Bay would be better than Motowheels or DOS extended stock swingarm.
I think it will depend on the cost and availability of the other parts.
Thanks for the input
Old 11-27-2006, 05:35 AM
Wheels for the large rear hub were made in 16, 16.5 and 17 inch sizes. They are fairly cheap and easy to find since most race teams would have multiple sets and they have no street application.
I bought a brand new Marchesini 17" rear for $400.
Old 11-27-2006, 01:56 PM
If it's a true Corse arm then the hub has a bigger I.D. and O.D. We have most of the parts you will need (Corse spindle, axel nuts, brake hanger, caliper, rotor), but don't see a hub so I'll look around some more.
Making Ducs fly since 1991
Old 12-01-2006, 12:06 AM
TrickLidz's Avatar
lidzduc.blogspot.com
That Ebayer's selling some trick parts!!
Old 12-01-2006, 09:48 AM
vtwin's Avatar
on the subject of swingarms;
what's the type of the LH side (sprocket) stock bearing in the eccentric? any part numbers?
When I had my eccentric off, I got the numbers from it and went to a local bearing shop, they came up with nothing. Is it a ducati-only -thing?
Thanks,
myducati.blogsome.com
Old 01-09-2007, 08:54 PM
rjjablo's Avatar
Default Will 1098 Rear wheel fit
' the large spindle and wheel nut closely resemble the pieces only used exclusively on the full racing Corse models. "
I found this in an online review for the 1098.
Any idea if the 1098 rear wheel will fit the Corse Large hub and spindle for the 748-916-996.
Any idea on offset?
Pin number and spacing?
Old 01-09-2007, 09:05 PM
foggy123's Avatar
Just sold my Mg swingarm to a member here. It was a big hub swingarm that used stock size axle. 19mm longer. I'm sure there will be pics up as soon as the new owner gets it on.
Old 01-13-2007, 10:02 AM
Default possible for sale
I have a mag swing arm complete with bilit rear caliper, hanger, upper suspension link and adjustable ride height bar, chain rubs and carbon guard that is in my garage. what are they going for right now? What is fair? I need to get a truck this year so i can get my 998 to the track.
Never Quit
'02 998 Yellow mono
'02 748 Yellow-converted
'97 748 Yellow-dead
'95 916 Red
'97 GSX-R Red-gone
Old 01-13-2007, 08:28 PM
PM sent!
Old 01-14-2007, 06:49 PM
bc1 bc1 is offline
I have wheels for this swingarm if anyone needs them. SORRY for the thread jack.
