We have a Tubi/HPE titanium -inconel 54mm system for the 996R /998R that has a small blem on the titanium can from shipping that we can make you a great deal.
We also have a rare Termignoni 50/54mm half system in stock that fits anything with a 50mm head pipe--which your 996R has...
the Akro is one of if not the best produced full system for your bike for the money and performance. fully tapered 45/60mm system with reverse tapered core cans. the only thing close to this level of construction is a full on Corse Termi system which will run you $5K or so if you can get someone to sell you a used one off an ex race bike. You can get the Akro for under $2K I believe. Termi stuff is overweight, over priced, and under performing compared to this product.
Check your MBP rockers......Check your MBP valves......
As Bruce would say... the 3 P's...Pistons, Ports, and Pipe. I've got 60mm Termi's with Pistal HC pistons and porting by Bruce, along with custom FIM and Pipercross air filter. Added about 21 rwhp over stock, plus got torque over 80 ft/lbs.
Depends so much on what you are doing with the bike, really.....
The best results I ever had with 998 "S'" or 996 "R" engines was with the full 57mm Termignoni system, .9mm squish, VERY carefully set up cam-timing, with the cams slightly advanced, DT-1 air-filter, Elf race fuel and the Ducati Corse "Superstock" ignition box.
Akropovic evolution full titanium system - super light and super performance. Let me know if you want more details...
Give me all youŽve got mate!
I am from across the pond, so I guess I gotta pass on the offer. But thanks anyway and maybe someone else reads this
Why is the 45/60 full system better than the other full systems? ArenŽt the other systems 60mm everywhere (even at the cylinders)? Or are all full systems starting at 45mm at the cylinder outlet and then go bigger?
Rhhhaaa, lovely !!!!
I actually just want to get that thing on the track and slap on the best working exhaust for it. No engine mods as of now.
Don't mean to hijack the thread but which system is considered the better one if you're planning on tuning a 996R or 998R (in my case) to about 170-175hp (measured at the crank, that is)?
I've heard good things about the MotoCorse 60.5mm system but then again, it's awfully expensive
Are there any good, cheaper alternatives?
I was thinking about putting my 998R back together a few weeks back. I was looking at about 160hp and was going to go with the Akropvoic (sp). They are about $2000 on the LP Privateer racer program.
