These roller bearings are
inside the final drive about 1/4 of an inch and they look like they belong there. I don't recall seeing any way to put a cage type bearing inside the shaft passage. Keep in mind these bearings are inside the final drive shaft not outside. These bearings are not pieces and parts that found their way inside but definitely look like they belong right where they are.
I am really not looking forward to disassembling the clutch again just to verify that what I saw was really what I saw but if I can't find someone who can offer any more information it looks like I will have to. I am starting to question myself the more I think about it.
I installed a new push rod after slopping some grease in the bearings and gooed up the ends and shaft of the push rod with fresh grease but not overly so. Everything went in place easily and funtions correctly.
This is one of those times when a little conservatism could go a long way. I can see it now. After fighting with the bottom bolt that holds the rear shock
and ride height adjustment rod to remove the shock for a rebiuld all afternoon I get frustrated and ignor some weird anomaly that will bite me hard in the ass.
That bottom bolt absolutely refused to break loose. I used an impact gun, heat with a pen type torch, a two foot cheater bar and went through three 8mm allen sockets by twisting them up. I ended up drilling the damn nut/bushing out from the right side. Somebody is now going to tell me
the beotch is a left hand thread, tried that too.
My 916 was a Horrid Blood Sucking Bitch.
