Suggestions for Rearsets & Clipons for a 2004 999? - Speedzilla Motorcycle Message Forums
Old 11-19-2006, 02:03 AM
Default Suggestions for Rearsets & Clipons for a 2004 999?
Just crashed my 2004 999 at a trackday and I'm since I have to replace some stock parts anyway, I'm looking to fit some suitable rearsets and clipons. Advice/suggestions? I find the stock bars a bit of a stretch, so clipons that were up and back a bit from stock would help. Easily-replaceable component parts for bars, pegs and levers would be good too.
Old 11-19-2006, 02:47 AM
Ubermoto's Avatar
Yoyodyne or Motowheels sell adjustable rearsets for your bike and also clip-ons. The Yoyodyne are machined nicer and you can use the Motowheels race brake/shift levers with them.
ubermoto #71
Old 11-19-2006, 03:01 AM
Send a message via MSN to TOPENDZ
I like acculign.
TOPENDZ - Unque products with great service and no bollocks. ALL PRICES IN CANADIAN DOLLARS.
Old 11-19-2006, 03:54 AM
rotty900ss's Avatar
I like my Motowheels rearsets. Solid and cheap. Irene has Woodcraft clipons on her 749S and she likes them. Again, solid and cheap. They are also easy to repair/replace.
Martin
'05 749R (Track only)(Termi half system, EVO slave, Woodcraft rearsets, CF hugger, AxlJak clutch cover, SpeedyMoto frame sliders, Starlane GPS laptimer, Yamaha throttle tube)
(Wife's ride) '04 749R red (#244)(ZARD full system, STM slipper, Yoyo slave, Motowheels rearsets, Puig DB screen, and CF hugger, heel guards, and heat sheild, custom AxlJak clutch cover)
'08 1098S black (SOLD)
'01 900ss red (reduc #992)(SOLD)
'98 YZF-600r blue (SOLD)
Old 11-19-2006, 04:13 AM
Sagerider's Avatar
Default Cycle Cat
I have Cycle Cat rear sets on my Fila and love them. They are adjustable
in just about any direction you can think of. One of the best features, I think,
is the locating pin that fits inside. This pin is captured so if the foot rest ever
gets loose the foot rest won't flop down. If the bolt that holds it on comes off
you will know about it because the foot rest will fall off. They are a little pricey
at around $500.00 but worth it.
My 916 was a Horrid Blood Sucking Bitch.
Old 11-19-2006, 05:03 AM
hubert's Avatar
Sharks in your mouth.
I had motowheels rearsets and I did not have a good experience; the hole through which the gear lever and brake lever pivoted had to be machined to get the drag out (I'd constantly not be able to shift and the rear brake would drag). Also, they didn't really have a great range of adjustability on my 996 to get me dialed in. With that said, they did fair rather well in a crash. I now have CycleCat rearsets on the bike and love them - great fit & finish in addition to an imrpoved range of adjustability.
As for clipons, I'd run stock or if you don't mind drilling them, run woodcrafts. The cyclecat adjustable clipons that I tried didn't have the range to get me into the track position I wanted, without causing clearence issues with the nose fairing, so I stayed with OEM clipons.
Old 11-19-2006, 05:04 AM
46Fan's Avatar
Default Just my two...
How do they look? Specifically, how is the anodize on the? What I've found is that the look of the anodizing is what really separates something that looks good from something that looks great.
The yoyodyne look to be the same thing as the MW ones.
Originally Posted by TOPENDZ
I like acculign.
Also, the acculigns don't seem to cost much more. Given their wide range of adjustability, do they have "too much" adjustment making it hard to find a comfortable setting?
Drinking Fountains are shorter than they used to be.
Old 11-19-2006, 03:36 PM
rotty900ss's Avatar
I thought I had a picture of the Motowheels mounted on my R, but I was wrong. I guess I'm a little different from others here, but I didn't really care how the anodizing looked as long as they were built well and gave me a solid platform while riding on the track. I doubt I have even looked at them since I adjusted them the way I liked them. Sorry, I kind of seen rearsets as a functional and disposable piece of the bike. I had the Acculigns on my SS. I thought they were nice, quite light and adjustable. I found them to be almost too grippy, IE my boot got stuck on them once or twice. I have also seen them post crash, and they pretty much get destroyed. Be sure to keep your stock rearsets in the toolbox if you run them. With the Motowheels, you might need to replace the peg, but the mount will still be useable, from what I have seen.
Martin
Old 11-19-2006, 05:35 PM
04749s's Avatar
i put on the Moto rear sets and found the same problem with the rear dragging , so i put the stocker back on ,, also put on FBF clipons and it helped .
But check these out http://ttr400.com/catalog_1.html
as i get older i know two things ... i can't hear you and it takes a lot longer to heal
... i forgot and where's my glasses ... mix and match
rides
01 ST2 04 998sFE
1 pissy german ole lady ( wanna trade )
Old 11-19-2006, 10:02 PM
MV-999R's Avatar
I really the Gilles rearsets
I just bought a black pair of Gilles for my 999R along with some black pazzos levers and love them
Bought them from here http://www.motomummy.com/gillesrearsets.html
Old 11-19-2006, 11:20 PM
Ubermoto's Avatar
Again, the Yoyodyne/Motowheels are of a similar Corse style design with the Yoyodyne having some grooves machined into the peg carrier and overall a bit nicer finish than the Motowheels - we use both and they are interchangeable. The Acculign have a similar amount of adjustability via the eccentric on the footpeg and shift/brake levers as the others with more of a focus on appearance and machining and they come with heelguards which is a deciding factor for some though I personally don't like the longer pegs on the Acculign and haven't experienced any drag issues with the Motowheels rearsets.
Acculign:
Yoyodyne:
ubermoto #71
Old 11-19-2006, 11:28 PM
jbraslins's Avatar
Send a message via ICQ to jbraslins Send a message via AIM to jbraslins
+1 on yoyodyne, not as expencive as other brands too
WERA Provisional Novice #134, NESBA I #134
2006 GSX-R750 (track only)
2003 Ducati 999 Mono (yellow, restoring from track to pristine street)
Old 11-20-2006, 03:00 AM
ANGUS's Avatar
Default clip ons....
I have woodcrafts and love them....but there is some obstruction of the OEM radial brake and clutch master reserviors with the bolt that allows the Woodcraft bars to slide in and out of their respective clamps. You must remove the masters to allow you access to this bolt to adjust the bar length.
Learn from your errors...however, errors can be costly.
Canadian
DOCC#953
Old 11-20-2006, 06:30 AM
Thumbs up
I had a set of Motowheels on my 999...JUNK!!!!! I went with Accilign, really good stuff and WAy adjustable!!!!!!!!!!!!!!!!!!!!!!!!!!1
