I believe that the forks will fit the triple clamps OK.
I hope so, as I have a set in reserve for my 998 if I have a really bad day.
I never checked the caliper mounts for offset, as I would swap the fork bottoms over so that I could still use the 998 mudguard.
As for the discs, I think 999 discs have a different bolt config, so together with the offset this looks like a no-go.
I will be interested as well to see anyon else's comments.
Spin
It's called the red-shift, and it's a result of the doppler effect. Basically, the faster something moves away from you, the redder it appears.
