748R piston weight? - Speedzilla Motorcycle Message Forums
Old 11-13-2006, 07:45 PM
vij vij is offline
www.virdung.net
Default 748R piston weight?
Next question. What is the piston weight on a 748R piston?
The reason for the question is that Kämna in Germany has 854 kits on sale.
http://www.ducati-kaemna.de/cms_en/angebot.htm
And this are the pistons I think.
http://www.ducati-kaemna.de/cms_en/k...el&artikel=973
It says 425 grams. They say that it does not need balancing but I just want to double check.
Jocke...........
MHR 900 1984
S4 984 2002
www.virdung.net
Old 11-13-2006, 08:53 PM
jhord's Avatar
The OEM one I have here is 411g w/rings/pin/clips.
Old 11-14-2006, 02:14 AM
I think they will vary some, we have a set here that are 419gms. I don't mind running pistons a little lighter and you should probably blueprint the engine anyway so can balance the crank then. We do a kit for $1300 with gaskets and cylinder exchange so thats not a bad deal. There is an "R" kit or a standard 748/854 kit (flat top).
Making Ducs fly since 1991
