Originally Posted by vij
When you assembly a standard 748R slipper clutch. The manual tells to put gears on the ramps. Does any one knows what type of grease it should be? Anything special or just normal genaral purpuse grease?
Jocke..........
High temp copper brake lube or something really close should work. Regular grease will just melt, fling off, and end up all over side of the bike and your boot.
