Mark - Is the oil pressure relief valve #14 in this diagram
http://www.bikebandit.com/part...6.asp the one you are referring to?
Also, for the 10mm banjo bolts, I was thinking about purchasing the banjo bolts from a 2000 996 and see if it bolts up to my 748 heads. If it doesn't, should I just buy the new plate from a 996? Would they bolt right on?
Loosecannon - Did you encounter any issues on installing your oil cooler?
I ended up purchasing an oil cooler with all the lines from Mark Hatten (Wounded Duc) and I'm in the process of buying the parts to install everything.
Thanks, Paul
