Details on setting TPS on a 999. - Speedzilla Motorcycle Message Forums
Old 02-14-2005, 05:22 AM
Default Details on setting TPS on a 999.
Could anyone elaborate on the procedure for setting the TPS on a 999. I have done this on a 748 and 996, but the 999 obviously has a different ECU.
I guess what I really need are the points/pins to take the voltage reading and what voltage I am looking for.
Thanks!
Old 02-14-2005, 11:15 AM
to do it properly you need a mathesis or some other software to do a tps reset, which tells the ecu 'this voltage = the default degree setting'.
if you close the throttle fully and read the voltage across the pins that give the tracking, add 100mv for a 999 or 65 for a 749 (100 for 749r) and that's your idle throttle blade setting.
from what jason has told me it appears the usa got the nominally '999' throtlte bodies. all the bikes we've checked have been consistant with having what i would expect are nominally '749' throttle bodies. they are physically the same part, but have a different p.n., which i assume is due to the base setting being different.
i can email you the procedure we use, but it involves the mathesis. we would use it to hook directly into the tps too, so i have no idea about which pins, etc, anyway.
Old 02-14-2005, 03:46 PM
Default Re: (brad black)
I'll take you up on that email and procedure. I have access to a mathesis.
kereams@yahoo.com
Old 02-14-2005, 05:35 PM
Default Re: (CuStOm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CuStOm &raquo;</TD></TR><TR><TD CLASS="quote">I'll take you up on that email and procedure. I have access to a mathesis.
kereams@yahoo.com</TD></TR></TABLE>
No need, it's posted right here http://speedzilla.zeroforum.co...37396
