Switching from dual injectors to single injector - Speedzilla Motorcycle Message Forums
Old 02-13-2005, 02:55 PM
Default Switching from dual injectors to single injector
Which injectors do you unplug when you are setting up a 996 motor for the track ?
I have a ulti-map single injector chip so I disconnected the outside injectors. It runs but is that correct ? I remember someone telling me there was a preference of which ones to disconnect (inner vs outer) due to the way it mists the fuel into the intake.
Any ideas ?
roadracer444
Old 02-13-2005, 04:49 PM
Default Re: Switching from dual injectors to single injector (roadracer444)
See the picture........
http://www.hyperpastabiker.net/new_page_5.htm
Old 02-14-2005, 11:26 AM
i always remove the outer ones due to the fact that the std single injector throttle bodies have the injectors on the inside.
i've dynod bikes both ways and seen no real difference.
Old 02-14-2005, 03:07 PM
Default Re: (brad black)
I removed the inner ones and everything works just fine.
Old 02-16-2005, 12:34 AM
It seems to make no difference - usually a case of which is easiest to get to.
Old 02-17-2005, 01:08 AM
Thanks to all the responses.
roadracer444
