Re: Bike Lift Is it safe to use. (duc1036)
Access to the left side is obviously more limited than the right but it is not a problem for me yet. I currently have the Monster up and had the entire rear end off (swingarm, peg brackets, etc.). This meant I could not use the side stand for extra security, but it was not bad at all. It will "wobble" a small amount but you'd REALLY, REALLY have to try hard to knock the bike off. Using the Ducati specific mounts, the bike sits on rubber sheathed arms (one front, one rear) with the addition of a pin that inserts into the unused hole at the rear of the cases. The pin is about 4 inches long if memory serves, so the bike cannot tip over. With the side stand clamped the bike is completely retrained.
The reason I finally decided on it instead of a normal table is that I would have needed more space for a table, tables (that lift) are FAR heavier, they don't get my wheels free without additional tools/stands, and quality lift tables are more money. Like I said, I spent over two years debating the pros/cons and I'm happy with my decision. The only way I would buy a lift table is if I had a large shop and did a lot of work for others or if I had a large shop with entirely too many slow moving projects of my own.
