Best final drive for a 1997 748 Bi-Posto - Speedzilla Motorcycle Message Forums
Old 01-06-2005, 02:26 AM
Default Best final drive for a 1997 748 Bi-Posto
I’m up for new chain sprockets & looking at making the most of what my bike does.
It’s a 1997 748 Bi-Posto, standard all ‘round except for Terminigonini cans & chipped to suit. Has 40,000kms on the clock. Currently has standard final drive of 14t front, 38t rear. (525pitch).
I ride mostly weekends/group rides/twisties & trackdays. No real commuting, or two/up.
On the safe side I was looking at going just a little shorter in the final drive (from 14t/38t) to 14t front, 39t rear, looking at getting that extra drive between the gear changes etc. I’ve heard of 14t/40t or 14t/41t, but this seems to be with a lot of track-focussed mounts. Just wondering what your opinion would be on this type of change?
Not sure if these figures for a 748 means anything:
Final ratio: RPM @ speed:
14/38 5336rpm 120kms/hr
14/39 5476rpm 120kms/hr
14/40 5617rpm 120kms/hr
Thanks !
Old 01-06-2005, 03:39 PM
Default Re: Best final drive for a 1997 748 Bi-Posto (Marx)
Probably the most popular gearing change for this model for street use is 14/41. If you want a better sense of how this gearing will feel, drop down from 6th to 5th with your 14/38 stock gearing. This will give you the exact same gearing that you'll get in 6th with 14/41.
Old 01-06-2005, 08:49 PM
Default Re: Best final drive for a 1997 748 Bi-Posto (Shazaam!)
I've got the 14/41 setup (hey, that's a palindrome - 14/41 !) with a Renthal quickchange rear sprocket.
I don't sit and drone on freeways particularly - that's not what the bike is for. It works great.
Old 01-07-2005, 12:06 AM
You could also try something else - and have a relatively cheap "quick change" setup by going for a bigger 15T front sprocket, with a 43T rear - which gives you similar gearing to a 14T/40T combo, and then having the option to switch to a 14T front, for an even shorter gearing for the very tight stuff.
Or, go for a 15T front with 42T rear, which is similar to a 14T/39T combo, and a nice alternative shorter gearing by switching the front to a 14T
....just a thought!
BTW - I think all stock 748's came with a 520 chain, unlike their bigger brothers....
Old 01-07-2005, 03:07 AM
Default Re: (Old Baldy)
don't think there's really a "quick" change on the old superbikes. when you start swapping sprockets, you'll have to adjust the eccentric to fix chain slack and then you start messing with ride heights....
Old 01-07-2005, 03:24 AM
You're right of course....OK, add 5 minutes to adjust the ride height, if ya want. I'm a cheap bastard, so it would work for me, as an alternative to a QC carrier and sprocket setup.
I'm too slow on the track to worry about multiple gearing changes at the track anyway....
Old 01-07-2005, 03:39 AM
Don’t forget ...
A 14/38 needs a 94-link chain.
A 15/43 needs a 98-link chain.
A 14/43 needs a 98-link chain.
A 14/42 needs a 96-link chain.
Plus, you’ll need to raise your rear ride height with the 14/43 and 15/43 combos. Don’t forget to measure your rear ride height before making any changes.
Old 01-07-2005, 03:58 AM
Default Re: (Shazaam!)
cool, thanks for all that.
I might go 14/40. Didn't consider the ride height after the change but I'll make a note of it..
Chain length shouldn't be a problem, doesn't the chain come in it's little box long enough for anything (trim & fit to suit)?
Old 01-08-2005, 01:32 AM
Yes - often 120 links, so you should have plenty.
Old 01-08-2005, 06:02 PM
Default Re: (Marx)
I put 14/40 from 14/38 on mine and it's a big improvement. Really wakes up the bike. Of course, you spin 'er up a bit more on those romps down the interstate, but it's really no big deal.
