where to find 998 and 999 wiring diagrams? splicing 999 injector wiring to 998 harness. - Speedzilla Motorcycle Message Forums
Old 01-05-2005, 02:58 PM
Default where to find 998 and 999 wiring diagrams? splicing 999 injector wiring to 998 harness.
hey gang,
anybody able to help me out with this one? i've got a 998 wiring harness/ecu/etc... to use with the 999 motor i'm stuffing into the s4. i believe it's all going to jive very well but the one gotcha i've run into is that the connectors vary for the injectors/TPS. so i've got to splice the 998 wiring harness to the 999's injectors/TPS wiring.
anybody got access to online wiring diagrams for both or either model? or can anybody explain which wire's which for each of those connectors so i can mate them up properly?
Old 01-05-2005, 03:02 PM
Default Re: where to find 998 and 999 wiring diagrams? splicing 999 injector wir ... (s4strati)
I can check the factory service manual (999) when I get home tonight. Can't help you with the 998.
Old 01-05-2005, 03:11 PM
Default Re: where to find 998 and 999 wiring diagrams? splicing 999 injector wir ... (negativegs)
awesome, thanks! could be 1/2 way there. anybody got 998 info?
Old 01-05-2005, 03:37 PM
Strati, I have my wiring diagram in the back of my manual and my bike is totaly naked right now since I am still rebuilding from my crash. I can look at both the diagram and the actual connections tonight if it will help. Phil
Old 01-05-2005, 03:38 PM
Default Re: where to find 998 and 999 wiring diagrams? splicing 999 injector wir ... (Phil 998)
that would be awesome phil, thanks. any chance you could scan it or snap a BIG pic? any help's appreciated as this is the only real hickup i forsee in completing the project.
Old 01-05-2005, 03:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s4strati &raquo;</TD></TR><TR><TD CLASS="quote">that would be awesome phil, thanks. any chance you could scan it or snap a BIG pic? any help's appreciated as this is the only real hickup i forsee in completing the project.</TD></TR></TABLE>
I've got a scanner here at work, but the manual is at home, so it would be tomorrow till I could do that, but would be happy to. I have a digital camera and could give that a try too. If you will be around tonight, you can also IM with a phone number and I can give you a call and describe the connections over the phone while I'm looking at them. Let me know what would work best for you.
Old 01-05-2005, 04:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil 998 &raquo;</TD></TR><TR><TD CLASS="quote">
I've got a scanner here at work, but the manual is at home, so it would be tomorrow till I could do that, but would be happy to. I have a digital camera and could give that a try too. If you will be around tonight, you can also IM with a phone number and I can give you a call and describe the connections over the phone while I'm looking at them. Let me know what would work best for you.</TD></TR></TABLE>
tomorrow's plenty quick phil, thanks. i'm not planning to slice into it until this weekend anyways. i appreciate it!
Old 01-05-2005, 11:16 PM
strati, let me know where you want the diagrams sent to.
Old 01-06-2005, 02:03 AM
if you could email 'em to me, that'd be great! stratihatzi@yahoo.com please.
Old 01-06-2005, 02:19 AM
Sent. You should have them by now. If you need anything else, let me know.
Old 01-06-2005, 04:15 PM
hey thanks! i really hate to be a bother, but you think you could scan the 2nd one (the actual wiring diagram) in again a bit larger? when i view it and try to increase the size to read the color codes for the different wires, it gets just barely too blurry to make out. thanks so much!
Old 01-06-2005, 05:00 PM
No problem. The one I sent is half the size of the original scan. I'll send it tonight when I get home.
Old 01-06-2005, 05:08 PM
rockin, double-size should be perfectly readable. thanks to you and thanks also to phil who also just sent me the 998 stuff.
cheers guys!
Old 01-06-2005, 10:40 PM
strati, hope you have a big inbox. Sent, all 1.5megs worth.
