<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>
Quote, originally posted by vfr31 »</TD></TR><TR><TD CLASS="quote">When you put it straigth up (and cold engine), you see the oil level coming up and filling all the glass!!
So I suppose that the level is too high? What are the possible consequences? And how can I remove some oil? I just add that the 600 miles maintenance has been performed by a Ducati mechanics
.</TD></TR></TABLE>
Yes there is too much oil in the motor. Possible consequence is through crankcase pressure it can force the oil up into the airbox where there is a drain line at the lower front and it will dump the oil out into the fairing and possibly onto the rear wheel.
Just put the bike on an axle stand so it is vertical and remove your right side body panel. On the bottom of the cases (I'm assuming a non deep sump) there is the oil drain plug, it takes a 10mm allen wrench to loosen. Just put a drain pan under the motor and keep the plug in your hand blocking the drain hole. Let a little out and screw it back in. Check the site glass and do it again until the level is half way up the glass when the bike is vertical. I don't recommend letting out a bunch of oil and then dumping it back in since you can knock off bits of dirt and grit while under the motor.
