Speedo drive on Marchesini - Speedzilla Motorcycle Message Forums
Old 05-01-2004, 08:01 PM
Default Speedo drive on Marchesini
2001 748.
Swapping over from stock to a Marchesini front. Is there anything special about the speedo drive on the Marchesini? I can't get the ring out of the stock wheel that drives the speedo. Do I leave that ring in the stock wheel and get some other adapter that drives the speedo on the new wheel?
Any help?
Old 05-01-2004, 10:59 PM
Default Re: Speedo drive on Marchesini (JamesP)
Should pop out with minimum amount of prying, just do a little on each side and work your way around.
Fran
Old 05-02-2004, 11:51 AM
Default Re: Speedo drive on Marchesini (sb748)
The dust shield should come out with careful prying but I would just replace it. I'm looking at a spare and the P/N is 000064471, Seal Ring.
Old 05-03-2004, 02:12 AM
James, you just pry the retainer ring out and use the stock one. On some Marchesini wheels the drive tabs don't fit. Just file enough off till the speedo drive ring fits down in the machined out area of the Marchesini.
Old 03-23-2005, 10:08 PM
Default Re: Speedo drive on Marchesini (Phil 998)
Hi Phil.
Just doing a search because I can't get the tangs to line up on my 10-spokes.Is this the trick to use to make the stock drive work??
Thanks!
Carlos.
Old 03-23-2005, 10:18 PM
Default Re: Speedo drive on Marchesini (riedel996)
If memory serves, the machined area on the Marchesini wheels is kind of a round shape and the two tabs on the speedo drive ring are a rectangle shape. I just filed the corners of the ring until it fit in the Marchesini and then put the original dust seal in.
Old 03-23-2005, 10:25 PM
Thanks Phil,
I just have to get the wheels off the bike,but it's soo hard 'cause I just keep GAUKING at my ride
So the inner ring will come out?
I was afraid that I was gonna snap off the ring and then a trip to the dealer for an overpriced speedo drive that's not in stock and I would have to wait 6 weeks for then the sun comes out and I still don't have the..........
Aw hell,let me do this now.
THANKS PHIL!!
Old 03-23-2005, 10:38 PM
Hang on Carlos, the part I'm talking about is under a seal ring in your stock wheel. I am not talking about the speedo unit that the axle goes through and the cable goes into. That part gets left alone. Phil
Old 03-23-2005, 11:00 PM
I sure hope he read this in time
Old 03-23-2005, 11:03 PM
Default Re: Speedo drive on Marchesini (YellowDesmo998)
Me too. His thanks will be retracted at light speed if not.
Old 03-24-2005, 12:20 AM
luckily again,my wife said let's go grocery shopping,so I had to delay the butchering of my speedo.
True,lucky I read Phil's post first.
I did not do anything yet!!!
WHEW!!!
Old 03-24-2005, 12:23 AM
Crap,I knew selling the stock wheels would come back to bite me in the ass.
They're long gone,was I supposed to pull that part off first Phil??
Old 03-24-2005, 12:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riedel996 &raquo;</TD></TR><TR><TD CLASS="quote">,was I supposed to pull that part off first Phil??</TD></TR></TABLE>
I'm not Phil, but I am a hell of a lot better looking and I have this pic:
Yes... part #7 (speedo drive caspin) and part #6 (drive seal) should have been taken off the old wheel.
Old 03-24-2005, 01:16 AM
Default Re: Speedo drive on Marchesini (Mental998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mental998 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not Phil, but I am a hell of a lot better looking </TD></TR></TABLE>
Bastard, just because you get parking close to the door you think it's because of your looks
Old 03-24-2005, 01:44 AM
Kind of a hijack but this thread reminded me.
If I buy Marcesini Mags they come with bearings and all the stuff I need to mount them, right?
I just need to swap over my disks and this speedo drive thingy and I'm good to go, correct?
Old 03-24-2005, 01:56 AM
Default Re: (jasont_ot)
Correct. Sometimes you don't get new aluminum valve stems and they are about $25 for the pair.
Old 03-24-2005, 02:01 AM
Great. Thanks Phil.
Old 03-24-2005, 04:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil 998 &raquo;</TD></TR><TR><TD CLASS="quote">
Bastard, just because you get parking close to the door you think it's because of your looks </TD></TR></TABLE>
Looks,Brains,and a hot bike can get you pretty far in my book!
