Motowheels Streetfighter - Speedzilla Motorcycle Message Forums
Go Back   Speedzilla Motorcycle Message Forums > Ducati Message Boards > Ducati Streetfighter
Old 06-24-2009, 04:46 PM
Default Motowheels Streetfighter
We received our Streetfighter a few days ago. We finally found some time to work on it.
We have a lot of product for the Strreetfighter in stock,
so we replaced what we thought would make the biggest difference first.
Here are the results after our first day:
BST CF 7 spoke "Street" Front Wheel: 848, 1098, 1198, Streetfighter, HM
We also added a pair of RHINOMOTO Front Axle Slider: Ducati 1098/848 and a CF Front Fender "Diversion"
BST CF 7 spoke "Street" Rear Wheel: 1098, 1198, Streetfighter
The OBERON Clutch Slave Cylinder 29mm will reduce the lever effort by about 30%. It has become our favorite because it is easir to find neutral than the 30mm slave cylinders , the finish and color selection is good. The price is 35% less than the others as well.
A SPEEDYMOTO "Leggero" Sprocket Cover replaces the original plastic sprocket.
We reversed the linkage so we could get "racer" shifting. We will add a reverse shift lever later.
The MW Folding Clutch Lever: 999/1098/S4RS/HM-Black allow us to adjust to a more comfortable position. The folding feature reduces the likely hood of breaking the lever which can leave you stranded far from home or end your track day.
The OBERON "Bar End" Turn Signals: Black/Pr and CRG Blindsight Mirror are our favorites for turn signals and mirrors. They are hardly noticable when on the bike--yet the mirrors provide a very good view of traffic behind you. The turn signals on the barends light up front and back and can be seen day or night.
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:47 PM
Default exhaust
We installed a Termi slip-on system for now.
Quat D is making a very interesting modular system for the Streetfighter that will allow you to use the same cannisters in three different configurations: STD position, Higher position with new midpipe (where the top pipe will be mounted above the current top pipe) and a full system with one cannister on each side using all new pipe.
-M
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:51 PM
SPEEDYMOTO Clutch Pressure Plate: Shinobi Pro
SPEEDYMOTO Clutch Spring/Keepers Kit
SPEEDYMOTO Clutch Cover: "7 Spoke"
When we have some more time, we'd like to fit the SPEEDYMOTO Billet Clutch Case.
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:53 PM
Just got a few of these carbon pieces in:
CF Radiator guards: Streetfighter:
CF Heatshield: Streetfighter:
CF Keyguard: Streetfighter. :
CF Sprocket Cover: 'Closed' 1098/848 :
CF Chain Guard Cover: 848-1198, SF :
Under tail (2 pieces):
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:54 PM
Under tank:
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:56 PM
SPEEDYMOTO Billet H2O Pump Housing: '02+
SPEEDYMOTO Frame Sliders: 1098,999,749S/R,998
SPEEDYMOTO Crankcase End Cover: Coat of Arrms
We used the CF Rear Hugger: 1098/848 "Short" . It has a mounting hole in the wrong place--so we used double sided tape to mount the 3rd point. We'll fit the extra hole with a bolt head. We'll have a more couple new fender options soon. We just wanted to get rid of that huge fender.
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:58 PM
End of Day one:
Leftover parts from out-patient surgery:
We have a lot more planned for the bike. Once things get settled down, we will start up again with some more mods.
-M
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 04:59 PM
some shots outside:
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 06-24-2009, 05:24 PM
foggy123's Avatar
Nice work!
What about putting a supercharger on it!
Speedzilla photogallery.
Old 06-24-2009, 07:42 PM
Originally Posted by foggy123 View Post
Nice work!
It's on the "to-do-list"!
-M
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 07-26-2009, 12:11 AM
Default Streetfighter high pipe full system.
We just installed a high pipe "full" system on our project bike.
-M
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 07-26-2009, 01:14 AM
First nice bike.
Do you know if the Oberon turnsignal kit also comes as a front running light option?
Thanks,
Larry
VFRrider
Old 07-26-2009, 09:05 PM
The OBERON "Bar End" Turn Signals: Black/Pr are turn signals only - however I never tested them on a bike that has runnning lights wired in to see if the LEDs would work like running lights.
-M
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 08-01-2009, 04:47 AM
drthompson65's Avatar
Why do you guys always make me want to spend money?!?! I'm going to be in divorce court yet...
Current Ride:
Old 08-03-2009, 01:47 PM
GAMBLER's Avatar
contra mundum
I like the Termi's better but what a nice project
