Featured Photos
by JDMerritt
Member Galleries
2098 photos
646 comments
by SRURC51
Member Galleries
2098 photos
646 comments
by rubio
rubio
1 photos
0 comments
by horwitzs
Member Galleries
2098 photos
646 comments
Old 07-29-2008, 04:29 PM
texbb texbb is offline
Default ST4S fairing rubber barrel attachment nuts
I pulled the fairing, left and right side panels off and found a couple of the rubber attachement nuts are in pretty bad shape. I had a spare and tried to push the flared end through the small hole and found it to be nearly impossible? How do you replace these? I tried to push through with a small screwdriver and buggered it up, tore the rubber a bit. I tried pulling through with small needlenose pliers and stretched the rubber shoulder and tore it some more.
How do you thread these guys through the small hole!!
thanks
2003 999 yellow, termignoni, Ohlins shock w/ hydraulic preload, puig windscreen, helibars, Ohlins steering damper, carbon fiber
2005 ST4S red, heli bars, airbox mods, K&N, pazzo's, traveling machine
2001 BMW R1100 SLA black, staintune, Induct, K&N, FIM chip, Ohlins front and back, carbon fiber
Old 07-29-2008, 11:55 PM
Double W Double W is offline
Hey Texx,
I replaced a few of the wellnuts on my ST4 last year, and I experienced the same issue you are having. A quick spray or silicone lube did the trick...they went right in. The other thing I did was put a tiny dab of never seize on the screws, and they come right out every time I do maintenance, saving the wellnuts.
Good Luck.
WW
Old 08-10-2008, 03:37 AM
sideways sideways is offline
Dis Member
Very good advice. +1
Carrmoto
Ducati Indianapolis
Old 10-23-2008, 06:11 PM
demontech's Avatar
demontech demontech is offline
livin the high life
install them from the back, squish the head through and done
