Mirrors - Speedzilla Motorcycle Message Forums
Old 07-30-2005, 11:34 AM
Default Mirrors
My right mirror is kinda loose, while my left mirror is not. A random sampling at the dealers showroom shows that about half the ST3/4's have loose mirrors on one side or the other. Does anyone know which is correct, loose or tight? The owners manual does not mention anything that I can find.
Old 07-30-2005, 08:24 PM
Default Re: Mirrors (2vtwin)
One of mine is loose also... Can't figure out where to tighten it...
Lookforward to other posts on this.
Brian
Old 08-05-2005, 08:50 PM
Default Re: Mirrors (ducsrule)
both of mine are loose....not where it bolts to the fairing, but the mirror extension itself. Been like that for 45,000 miles...so I guess it's OK.
BTW..they're spring loaded and the spring tension tends to loosen..
Old 08-23-2005, 06:31 PM
I noticed my right is nice and steady and have more vibration in the left one.
Old 10-05-2005, 05:55 AM
Default floppin mirrors
ST mirrors are designed to bend over when bumped, then the internal spring brings them back. if they a pushed too far or bumped alot, they get a little loose feeling. unfortunately, you cannot replace the spring, you have to buy a new mirror. some other options are to reseat the rubber gasket at the fairing so that the thin edge is up around the mirror stalk; if you look closely, they usually are not seated after being bent over. this is kind of a pain and usually requires a sixpack and/or friend to share in the miserable job of taking the upper inside fairing apart to get at the mirror mount. if they get real loose, put a home depot self tapping screw into the bottom of the stalk near the fairing gasket. preferably on the bottom, and use a small, short, black one. although, even when they feel loose to the touch, they still seem to stay put at speed, maybe a little more vibration. this makes the flashing blue lights stand out better, but does make the unlit light rack a little hard to see prior to ignition.
