Wheel Removal on ST4S - Speedzilla Motorcycle Message Forums
Old 06-24-2005, 11:55 AM
Default Wheel Removal on ST4S
> For a friend: This probably sounds bad but how do you remove the Front and rear wheels on an ST4S? I have done it many times on my 900ss and M750
> but have never dealt with hollow axles. It appears straight forward but what size sockets are needed and soforth.
Thanks, Don
Old 06-25-2005, 06:31 PM
Default Re: Wheel Removal on ST4S (Sogno)
It should be a 28mm for the front, and a 30mm for the back.
Try to get sockets that don't have a big 'taper' or radius on the end, as the nuts are shallow and thin walled, you need all the engagement you can get. You can grind a bit off the end of the socket to improve that.
Otherwise, it's the same deal as removing the wheels on your M or SS.
I've found the rear is easier to install if the caliper is removed, the caliper bracket is enough of a struggle by itself.
