Clutch Push Rod, Orientation? - Speedzilla Motorcycle Message Forums
Old 06-11-2005, 05:52 PM
Default Clutch Push Rod, Orientation?
Which is the correct orientation of the rod: with the two o-ring end near the slave cylinder, or with the two o-ring end near the pressure plate? The only diagram in the service manual shows it in what appears to be the two o-ring end near the slave cylinder. That would be the opposite way I just found it!
Before I fix something that's not broken... which is the correct way?
Thank you.
Old 06-12-2005, 07:31 PM
Default Re: Clutch Push Rod, Orientation? (DanST4)
O-rings on the clutch slave side of the engine. Thanks Dan!
