st3 adjusting back suspension - Speedzilla Motorcycle Message Forums
Old 05-06-2005, 11:30 AM
Default st3 adjusting back suspension
hi people..just a quick question,i want to set more preload on the back spring but find it impossible to get the c spanner to fit the ring on the top of the suspension,it seems its poissible to adjust it towards a softer option which i did earlier,but the frame gets in the way from whichever angle i try........does any body out there know of a simple remidy ????
Old 05-06-2005, 06:07 PM
Default Re: st3 adjusting back suspension (massa8)
Excellent question. Both I and a buddy of mine couldn't figure it out on my bike either. There's just no room.
Old 05-07-2005, 03:58 PM
Default Re: st3 adjusting back suspension (tbird245)
yea tbird,ended up using a large screwdiver and hammer.............a soft small billet of aluminium would be better to avoid damage to the segments on the ring........what is this for crap anyway,i would expect this on my sons bicycle from spears and roebuck....................its not as though the motorcycle is cheap throw away stuff from chequaslovakia.........cant even spell the name
Old 05-09-2005, 02:21 PM
It is possible to use the c spanner. Difficult, but possible. Check with the shock manufacturer, somtimes they have very thin spanners that may fit.
Old 05-09-2005, 05:33 PM
Default Re: (georgeb)
Had the seat off this weekend and I noticed that if you remove the black plastic tray that's in the front you may be able to get at it that way. Haven't tried it yet though.
Old 05-09-2005, 10:04 PM
I really like the 3 except for that rear stock which is just plain stupid so I'm checking out the cost of an Ohlins which may be around $800. Also stupid cause thats about half the difference between a 3 and a 4s. If you need to change the pre-load frequently for a pillion it's a major PITA.
