Originally Posted by chromekid01
I like it. Is this your own design? or can i buy it somewhere? it looks like a 2 into 2 exhaust is it?
Personally I like the MIVV cans for the MTS series.
http://www.mivv.it/moto_usa/prodotti...oto.asp?id=745
http://www.mivv.it/moto_usa/catalogh...o_sportivo.pdf
They also make a cat-less-header (mid-pipe) so you can remove the lovely square box from under your engine. I would buy the MIVV Race Titanium (NON X-CONE!!!) with the mid-pipe, BMC air filter, PCIII USB and make a custom air box top like the FBF one. This is where you are going to get the most out of your stock engine. You could also open up your stock air box or use a Corse crankcase breather, with a longer hose routed towards the back of the frame, if you made your own airbox top (the stock crankcase breather hose is routed to the back of the stock air box). Like all Ducati's with this type of intake system (MTS, SS, M ST...), they all benefit well when you increase the amount of air coming into the engine. Even the Ducati Performance air box with high flow air filter has very two small intake holes, much more torque and horsepower can be made with a larger intake.
WHY HAS NO ONE MADE THIS FOR THE MTS SERIES YET??????
