What cams? - Speedzilla Motorcycle Message Forums
Old 05-10-2007, 10:51 PM
Default What cams?
im gonna put some new cms in my v2 engine!
im need input on which ones to get!
Old 05-10-2007, 11:17 PM
Default cams
I Had Bruce from BCM do my heads 2 years ago and he put stock 900SS cams in mine and they work just fine,,,,,along with a nice valve job,port work,not to wild it is a street bike,,!!!!!. 6 to 8 track days a year
Old 05-11-2007, 04:11 AM
depending on what size motor your monster is......the 98 ST2 cam is actually the most aggressive cam made by ducati for the 2valve motor, not sure if it fits into the smaller motor, but its a cheap upgrade for a 900. On top of that, make sure to degree the cam, i think you are looking for a centerline of 112. Have fun!
Old 05-11-2007, 12:41 PM
marvin's Avatar
Give a little thought to what "type' of engine you want. If you have the long intake manifolds :"ala carby" you may be better off with the stock cams degreed and perhaps advanced a bit, (low-mid range torque). The St2 cams will work best with short intakes or the FI set-up, You will loose a bit on the lower end and gain it on the top. I am slowly building a 94' Monster with 944 kit, etc. and decided to go with the stock cams, long intakes and 41 flatslides, plan on shifting around 8K and gear accordingly. Just my 2 cents!
Old 05-11-2007, 04:31 PM
Default ..
well i have:
Spegetti exhaust termi
keihin 41
bucci 944 hc kit
pod filters kn
lightend flywheel
al9000 ignitionboxes
900ss heads and cams since i had the 1997 with the small 750 heads.
big ass portjob being done as we speak and thats why i wonder which cams to go for.... dooh i have the long manifolds not good!
I wont more top end power since i have big big low end grunt right now!
im hoping to at least break the 90hp barrier.
st2 cams i have been thinking about but they are only 130 dollerd less then veetwo.
Old 05-11-2007, 04:39 PM
marvin's Avatar
Originally Posted by lechef View Post
well i have:
keihin 41
bucci 944 hc kit
pod filters kn
lightend flywheel
Sounds like you have all of the "good stuff" except for the short manifolds. contact Chris Kelley at ca-cycleworks.com He was working on supplying the short manifolds I believe.
Old 05-11-2007, 07:24 PM
Default yeah
But i have the dual set keihins and not the single ones!
That is the bad part.....
Old 05-11-2007, 07:46 PM
marvin's Avatar
I figured that you did. Used 41's go for almost as much as new units on ebay. It all depends on where you want to make power!
Old 05-14-2007, 11:00 PM
Default ..
Where can i get hort manifolds for the keihins?
Malossi type...
