monster forks in 916 triples - Speedzilla Motorcycle Message Forums
Old 12-19-2006, 09:58 PM
Default monster forks in 916 triples
hi.ive got a set of s4 monster forks 54mm,that i want to fit to 916 triples 53mm..........is it ok to turn down the fork diameter by 1mm rather than bore the lower triple?////////////any ideas?thanks
Old 12-20-2006, 07:24 PM
foggy102's Avatar
Track Junkie
I would bore the lower triple as you can see exactly how much material you're working with. Anything but Magnesium should be no problem and much less expensive than fooling around with the forks.
J
DOCC #668
100% Track Bike... Termignoni full system, Racing ECU, open airbox, lightweight flywheel, Carbon front fairing, 999 Ohlins with custom Ortner triples, rear Ohlins shock, Pazzo levers, Fuel tank quick release, Mag Marchesinis, BiTubo damper, 520 conversion [14t front/39 rear], Woodcraft clipons, Carbon/Billet quick release fuel cap, Braking rear rotor, MPL tuning clutch slave & billet cover, CycleCat rearsets, full chop rear...... $$$$$$ help!
Old 12-24-2006, 12:28 AM
member at large
i agree with foggy102. its a hell of a lot easier to bore out the lower, quick work with a boring head. however if you have to disasemble the forks for any reason its nothing to zip off a mm in the lathe. and not to mention the mistake factor (this seems to affect only my stuff...) its a lot easier (for me) to make a boo-boo with a boring head,
just remeber one thing measure twice, cut once.
Old 12-25-2006, 11:45 AM
Send a message via AIM to Cozzb
Plus you would probably want to have them re-anodized.
Old 01-12-2007, 02:26 PM
gixracer's Avatar
Send a message via AIM to gixracer
dont turn down the forks!!!!!!!!!!!!!!!!!!!
get the triples bored
the price of fork tubes for resale is more that a set of used triples.
the pain involved in turning fork tubes is emense plus the wall thickness and the anodizing plus the dissasembly problems. it just get expensive fast.
HE WHO DIES WITH THE MOST TOYS WINS
