Re: Ceramic Brake Rotors on a monster (Rideon)
Per the BrakeTech website, a CMC rotor is a little over 2 lbs. lighter than an OEM SS rotor.
I assume the weight savings is the same compared to the BrakeTech Ductile Iron rotors. The website doesn't give the weight of the iron rotors, if they were lighter than the OEM rotors I'm confident they would talk about it.
A pair of the CMC rotors will trim 4 lbs. off of a front wheel, which is substantial.
My cast mag front wheel was roughly 3 lbs. lighter than my OEM 5-spoke cast aluminum Marchesini. IIRC, Rideon has forged mags, which are a bit lighter yet.
Likely you would feel the difference in ease of 'turn-in', it won't be as dramatic as the difference with the mag wheels, as the diameter of the rotors is roughly half.
The bike will accelerate and decelerate quicker, first because it is 4 lbs. lighter, and second, due to the reduced rotational inertia. You probably won't be able to feel that, as it would be roughly equivalent to taking a gallon of gas out of the tank.
The ride/suspension quality will improve due to the reduction in unsprung weight.
You should be able to feel that as well.
My rough guess of the 'feel' differences from a set of the CMC rotors (as I'm so woefully short of accurate weight and dimension data that it's not worth calculating anything) compared with the switch to mag wheels:
Straight line acceleration, 5 - 10%
'Turn-In', 25%
Suspension compliance, 100%
The braking 'quality' of the CMC rotors is an issue which I've heard nothing about.
Personally, the OEM SS rotors with the OEM pads were a bit too grabby for my taste.
Too much bite with a light squeeze. For heavier braking, they were just fine.
My BrakeTech iron rotors with Ferodo platinums are nicer, IMO. Initial bite is less, and heavy braking requires a bit firmer squeeze, but a good 2 finger squeeze will still stop the bike very quickly.
Fade resistance? I've heard nothing. Frankly, IMO if you're fading even OEM front brakes on the street, you're riding much too hard.
Weight loss in the wallet will be about par for the course, about 5 franklins per pound.
You can trim weight elsewhere on the bike for less $/lb, but the benefits are less.
