Monster - Termignoni high mount question - Speedzilla Motorcycle Message Forums
Old 05-21-2005, 03:35 AM
Default Monster - Termignoni high mount question
I want to put a set of slip on carbon fiber high mount Termignoni's on my 2003 Monster 620.....Will that eliminate my passanger footpegs? Will the fuel injection compensate for the change in exhaust flow? Anyone have some pics?
Old 05-21-2005, 04:33 AM
Default Re: Monster - Termignoni high mount question (raptor826)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raptor826 &raquo;</TD></TR><TR><TD CLASS="quote">I want to put a set of slip on carbon fiber high mount Termignoni's on my 2003 Monster 620.....Will that eliminate my passanger footpegs? Will the fuel injection compensate for the change in exhaust flow? Anyone have some pics? </TD></TR></TABLE>
no you will not need to remove the passenger pegs and no need to do any thing to the FI. if you open the airbox then you will need more fuel to the mix but as your only adding slipons there is no need to touch the FI and a/f ratio should stay the same as before.
sorry i can't help with a picture of a 620 with high mount slipons. good luck
Old 05-21-2005, 03:44 PM
I have hi-mount DP's on my 620. When I added the open air box the throttle response got real jerky so just be aware of the potential for that. I went back to the closed box, w/o FI adjustments and all seems to be in order.
The cans mounted up no problem with the stock rearsets as well.
Good luck.
Old 05-23-2005, 10:58 PM
Default Re: Monster - Termignoni high mount question (GregP)
Old 05-24-2005, 03:27 AM
Default Re: Monster - Termignoni high mount question (spolic)
Guys, thanks for the info and the pics.
