Been suffering from deteriorating part throttle performance and poor idle quality and stalling for a little while now. Now it's not rideable.
Runs OK immediately on startup, but a minute or two of running and it starts missing on the back cylinder, backfiring out the intake. It will get worse until the engine stalls.
I synced the throttle bodies best I could with the intermittent running.
Runs just as crappy with the filler open, so there's no tank vent issues.
New spark plugs, still bad.
Snugged up hose clamps on the manifolds.
PCIII removed.
Swapped coils front to rear, rear cylinder stays bad.
If I unhook the coolant temp sensor, the fans will come on. So I think the coolant sensor is OK.
Battery is good, reads 13V on a good multimeter.
Both injectors read 13 ohms.
Little filter screens on the injectors are clean.
Can't check fuel pressure tonight, but I'll have that capability tomorrow.
Next is swapping injectors to see if the problem follows those.
Anybody got any bright ideas? or BTDT?
-----------UPDATE------------------
Valve train:
Belts tension is OK.
Cam timing marks line up like they should.
Nothing obviously wrong with the valve gear and cams, haven't removed any of 'em for close inspection.
Intake opener clearance .004".
Exhaust opener clearance .005" & .006.
Closers have clearance, no measurements as that's a real PITA.
Closer springs are not broken.
Turns out I can't check leakdown at the moment, I don't have an adapter that'll fit the small plug threads.
Inspected the near-new plugs.
Front cylinder spark plug looks fine, like it's been running.
Rear still is very new looking and still white.
I'm beginning to suspect there's a fuel delivery problem....
Modified by Speeddog830 at 8:45 AM 4/2/2005
Modified by Speeddog830 at 7:39 AM 4/14/2005
