<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>
Quote, originally posted by s4strati »</TD></TR><TR><TD CLASS="quote">
cams/pullies are definatley intgerchangable between the two bikes, though you'll need longer belts to run the 996 heads. one issue to be aware of is limited clearance between the longer 996 horizontal head and the front tire on full suspension compression. also, not sure how much room there'll be for the battery and whatnot under the tank.
check out the "foggy owners" thread for some posts from infoage1. he's put some 916 heads on his s4 and may be able to help sort out fitment issues with you.</TD></TR></TABLE>
http://www.moto-one.com.au/per....html
The only things I can add are:
I do believe the tensioning and idler pulleys to different between the S4 and the SBK. My SBK belts were too tight with S4 pulleys and SBK heads. Not so after I milled the heads
Head to front tire clearance is "ok" but not generous at around 5/16" (bottomed, no load). I have bottomed my forks, and did not hit. I may be getting a new set of triples in the near future, if so, maybe I'll lower the front end to take a more precise measurement.
The battery fits in under the tank fine. You will need to figure out something to support the rear of the battery tray. No big deal. I can take pics if you need. I shimmed the rear of my tank less than a 1/16" to allow a little more room for the tank wiring.
It might be possible to have the studs moved in your S4 cases, and bore the holes to allow the 996 cylinders and heads. If possible, that might be the easiest. Anyhow, it all sounds like a lot of work
