Re: S4 single side swingarm conversion (ducdude)
Ducdude-
I asked the same question when I first arrived on this board. Apparently, there is a lot of work involved, as the superbike and S4 frames are quite different.
The biggest thing is that the superbikes support the swingarm from the outside, whereas the Monster swingarm bolts only to the rear of the motor. As a result, the rear mount on the motor cases is about 15mm wider than on the superbikes. This means you will likely have to machine the rear engine case motor/swingarm mount. $$$$ The other alternative would be to get a motor from a 916 or 996 superbike and mate it to your frame, but using the superbike's SSSA.
I have seen some that have made it work somehow - and I would love to do it on my MS4, but I don't know that the trade-off would be worth the effort. I would rather spend the time, effort, and money on other stuff.
If you're interested, I have a complete superbike rear swingarm (arm, shock, linkage, rear hub) available in my garage. Make an offer.
Edit: I sold the SSSA I had
Modified by spezjag at 11:34 AM 12/27/2004
