warm the bike up to about normal operating temp. drain the old oil. add whatever weight, cheapo motor oil to the hi fill line. i do not change the filter at this point since it's just sitting there and no oil will be circulating thru it. (some will argue this point). you're done. the only down side is if you get a nice day in early spring you can't hop on and go for a ride without changing the oil 1st. my
. your results may vary, no warranty expressed or implied, etc, etc.
